which brake master cylinder w/booster bolts into 97 civic ex w/abs
Alot of the dx and lx civic guys use the type r mc/booster but is that abs?
And since i have abs i wouldn't be able to sucessfully use 99-00 si rear brakes because they are not abs. SO i would have to get gsr ones but then the e-brake cable will be a different length.
anyone have any input.
ps. I have read the huge rear brake thread in the archived topics but it didn't talk much about abs.
You can use SI brakes all around and they will work just fine. You will need the SI prop valve too and get the MC and brake booster from an ABS car, like a GSR or SI...
anybody else?
I have heard the prop valve on the ex and si are the same
but a gsr mc/bb won't fit unless u reflare the hard lines
Sivic90
Nov 14, 2008 04:23 AM
xBoosted4drx
May 3, 2005 10:39 AM
