ANOTHER HONDATA QUESTION??
I was going through hondata website looking for stuff I had to remove before putting on the system and it says this:
Remove the rising rate fuel regulator and replace with a fixed 1: 1 rising rate regulator set to a base pressure of about 60 psi.
Does that mean to set the FPR at 60 psi or get 1:1 disc for the fmu thanks for you help
that means remove the reuglultor that came with the kit (Silver thing which looks like fmu) and either install stock fuel pressue regulator or install another regulaotr that is 1:1. (eg aeromotive fpr, etc...)
