D15B 3-Stage VTEC
Old Sep 21, 2003 | 11:06 PM
Formula 1's Avatar
Default D15B 3-Stage VTEC
for all you guys needing to learn bout the d15b
http://www.leecao.com/honda/vtec/3stagevtec.html
Old Sep 21, 2003 | 11:46 PM
Katman's Avatar
Default Re: D15B 3-Stage VTEC (SikCivic)
cool little site there....
Old Sep 21, 2003 | 11:59 PM
Formula 1's Avatar
Default Re: D15B 3-Stage VTEC (Katman)
yes it is nice lil info u can go back and check out the rest of the VTEC links too pretty sweet
Old Sep 22, 2003 | 07:26 AM
KStuned's Avatar
that is some wierd ****! I just put a D15b into a 96 civic, and I am using a jumper harness and a P28, obviously the 3 stage VTEC won't work unless you are using the proper ECU, what is the ECU code for the 3 stage VTEC? I guess I will have to tear the valve cover off of that motor when I get to the shop today! I wonder if ALL of the D15b's are this "3 stage VTEC"?? Interesting. Thanks Matt.
Old Sep 22, 2003 | 09:04 AM
Formula 1's Avatar
Default Re: D15B 3-Stage VTEC (Hondaddict)
d15b should only come in jdm civics in certain years and only way to telll is the engine code if there is no numbers after the d15b its jdm and prolly 3 stage
Old Sep 22, 2003 | 11:03 AM
mugenracer's Avatar
3 stage vtec was called VTEC-E.......the site aboves info seems wrong, 3 stage vtec is the same as VTEC-E and they claim it produces 128bhp which is wrong, it only produces 92bhp and its purely an economy thing and has no performance attributes at all. Theyre available here in europe, i have driven one and they are the deadest/slowest honda i have ever driven, they take for ever to get to 60 and are just about flat out at 80mph. the engine that produces 128bhp is found in the jdm VTi and it is certainly not economical, they are actually more thirsty than my B18C integra!!
http://asia.vtec.net/spfeature/vtecimpl/vtec1.html
Modified by mugenracer at 8:16 PM 9/22/2003
Old Sep 22, 2003 | 11:57 AM
Formula 1's Avatar
Default Re: D15B 3-Stage VTEC (mugenracer)
it isn't vtec-e its a combo vtec-e and normal sohc vtec read the site that i posted the link to and read the vtec-e summary
In short, it combines VTEC-E and SOHC VTEC to get both extraordinarily good RPM fuel economy, and excellent high RPM power. The D15B is a 1.5L engine that is capable of about 54mpg and is rated for about 128HP
Old Sep 22, 2003 | 11:59 AM
Formula 1's Avatar
also tell me what the second engine from the bottom is then?
on this link http://www.hmotorsonline.com/s...it=15
Old Sep 22, 2003 | 12:41 PM
Nameless RB26's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenracer &raquo;</TD></TR><TR><TD CLASS="quote">3 stage vtec was called VTEC-E.......the site aboves info seems wrong, 3 stage vtec is the same as VTEC-E</TD></TR></TABLE>
No.. it's 3 stage vtec. It is NOT vtec-e.
Read it again.
Old Sep 23, 2003 | 11:24 AM
4crx4me's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondaddict &raquo;</TD></TR><TR><TD CLASS="quote">that is some wierd ****! I just put a D15b into a 96 civic, and I am using a jumper harness and a P28, obviously the 3 stage VTEC won't work unless you are using the proper ECU, what is the ECU code for the 3 stage VTEC? I guess I will have to tear the valve cover off of that motor when I get to the shop today! I wonder if ALL of the D15b's are this "3 stage VTEC"?? Interesting. Thanks Matt.</TD></TR></TABLE>
You should read it again closely, The D15B 3-stage has TWO VTEC solenoids. So to see if you have one, just look there. You DON"T need to look internally. And NO all D15B's are NOT 3 stage VTEC, it is slighty rare.
JDM and EDM Civic's EX's or equivalents only, I believe,and only for two years. '96-'97?? or '97-'98??
I should read it closer as well.
HTH
ChrisSRT
Dec 22, 2007 06:13 PM
97Ej6mike
Jan 7, 2007 02:13 PM
tobe1424
23
Apr 26, 2006 01:56 PM
craigie
Jan 16, 2006 01:33 PM
H4tchster
Dec 14, 2003 04:02 PM
