a dumb oil changing question
Old Sep 21, 2003 | 08:50 AM
sleepyhamsterlx's Avatar
Default a dumb oil changing question
OK, every damm time i change my oil, the oil from the oil filter gets all over my exhaust, and smokes for a day from all the oil that spilled out when i removed the filter. Is there a way to get the oil out of the filter before i remove it. thanks
Old Sep 21, 2003 | 10:06 AM
BlkWido98's Avatar
Default Re: a dumb oil changing question (Mgnlxsd)
Uhhh, no. What kind of car do you have man? If it's a b or h series block you just unscrew it and hold the filter in your hand. After that, crawl from underneath the car and dump it in the oil pan. If you can't do that then just get a towel every time you change your oil and wipe down the part of your exhaust that gets oil on it.
Old Sep 21, 2003 | 10:23 AM
bartek_b's Avatar
what kind car, year/model/make
Old Sep 21, 2003 | 10:50 AM
d357r0y's Avatar
Easy fix..
Put a walmart bag over the exhaust when you change the oil. Oil drips on the bag, throw away the bag and you are left with a clean exhaust.
Old Sep 21, 2003 | 09:40 PM
roydogg's Avatar
Default Re: a dumb oil changing question (d357r0y)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d357r0y &raquo;</TD></TR><TR><TD CLASS="quote">Easy fix..
Put a walmart bag over the exhaust when you change the oil. Oil drips on the bag, throw away the bag and you are left with a clean exhaust.</TD></TR></TABLE>
I'll have to give this a try .
Old Sep 21, 2003 | 10:27 PM
Stripped Honda's Avatar
99-0104
Default Re: a dumb oil changing question (roydogg)
use brake cleaner to clean the exhuast if you dont have a bag ...
J.nguyen
Oct 14, 2006 06:04 AM
lazykiwi
Dec 26, 2005 09:38 PM
Thasty
Honda Motorcycles
Sep 4, 2004 08:28 PM
lowgman
Apr 21, 2004 04:14 PM
RAS Motorsports
Jul 8, 2003 06:43 PM
