Question regarding synthedic oil
Old Sep 21, 2003 | 07:59 AM
2.2SICKLUDE's Avatar
Default Question regarding synthedic oil
I got my car out a while ago and just put in new oil but 3 months after that the oil seem too be very dark like its been in there for a long time? It looks dirty as well, could there be like some kind of a leak of some sort?
Old Sep 21, 2003 | 08:02 AM
Shakes's Avatar
space cadet
Default Re: Question regarding synthedic oil (JDMH22NLINE4)
you have a very dirty engine. when was the last time that you had it flused? if you dont know get it done. the dealership will rape you on it. go to a jiffy lube or something. should be about $80. it will clear things up a bit.
Old Sep 21, 2003 | 10:15 AM
Sticky Tires's Avatar
* B A N N E D *
Default Re: Question regarding synthedic oil (shakes)
well it depends on how hard you drive. do you hit vtec often? it would also help if you mention what brand of motor oil you're using.
also if any, the previous owner of your car didn't follow up on maintenence schedules.
Old Sep 22, 2003 | 08:17 AM
Default Re: Question regarding synthedic oil (Sticky Tires)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sticky Tires &raquo;</TD></TR><TR><TD CLASS="quote">well it depends on how hard you drive. do you hit vtec often? it would also help if you mention what brand of motor oil you're using.
also if any, the previous owner of your car didn't follow up on maintenence schedules. </TD></TR></TABLE>
well i drive my car pretty hard, vtec almost everyday, I push it to 7k at least once a day but that was when i didn't have any electrical problem and that's been like 2 to 3 months. I'm using Mobile 1 synthedic oil at the moment i think its 10w-30 or 40 . The maintnece is there im the second owner of the car and the motor was stripped out and then put all back together.
Old Sep 22, 2003 | 09:40 AM
bb6h22a's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMH22NLINE4 &raquo;</TD></TR><TR><TD CLASS="quote">I got my car out a while ago and just put in new oil but 3 months after that the oil seem too be very dark like its been in there for a long time? It looks dirty as well, could there be like some kind of a leak of some sort?</TD></TR></TABLE>
3 months ago? Oil, like anything else, degardes with time. Simply b/c it's not exposed to high heat, it still breaks down at room temp. I can't believe you say that it looks really dark, yet you say it's been in there for 3 months-- all within the same sentance. Change your oil, problem solved. Just because the oil's synthetic, doesn't mean it's got preservatives.
Old Sep 22, 2003 | 05:30 PM
* B A N N E D *
well i drive my car pretty hard, vtec almost everyday, I push it to 7k at least once a day </TD></TR></TABLE>
i would change the oil every month if i drove like you. your abusing the oil!
bigstevo106
Apr 25, 2006 06:00 PM
Civicse
24
Sep 12, 2005 08:46 AM
h2392si
16
Aug 25, 2005 07:18 AM
blackjdmEKcivic
Nov 14, 2004 09:38 PM
quazar
27
Oct 29, 2004 12:49 AM
