torque dampers??
Is that bracket bolted into the hole in the back of the head that the Helms manual says you use to hoist the engine out? Any different angle pics?
http://www.lhtperformance.net/
I saw a few nice crx's by them and they had a dampener thing for our cars I'm pretty sure. give them a call b/c their website doesn't list the piece
Modified by B16_madman at 8:48 PM 9/21/2003
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iwouldHITit »</TD></TR><TR><TD CLASS="quote">do they make a torque damper for the crx??cause i really need one cause this is the second time i snapped my motor mount bolts..
</TD></TR></TABLE>-/
how much did you pay for this?
</TD></TR></TABLE>-/-/
If you are using stock mounts would this stiffen up you're engine enough. I've got a D16Y8 that was put in using Honda OEM mounts and need to hold the engine more. Would this be an alternative to racing mounts?
Thanks,
VINCE
Thanks,
VINCE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Driven »</TD></TR><TR><TD CLASS="quote">that seems like a pointless mod.
Couldn't have said it better myself
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by azroth »</TD></TR><TR><TD CLASS="quote">Isnt it the job of the motor mounts?
not actually, the motor mounts support the engine on a vertical axis. without the the rear and two front brackets the engine would twist violently during acceleration.
[group 8, 10, 12] and [group 1, 11, 9] are for torque......
</TD></TR></TABLE>not actually, the motor mounts support the engine on a vertical axis. without the the rear and two front brackets the engine would twist violently during acceleration.
i would also like to know . if i get the damper i can make my own mounts . here`s the reason. https://honda-tech.com/zerothread?id=652505
Yuta
Nov 25, 2015 12:46 PM
