Assembling the engine.
Old Feb 4, 2005 | 06:22 PM
d16rice's Avatar
Default Assembling the engine.
What should and where should I use when assembling the engine (thread-lock, anti-seize, lube, etc.)
The engine block is assembled and so is the head; I think I just have to put them together and hook everything up.
Old Feb 4, 2005 | 06:24 PM
dogfood's Avatar
Default Re: Assembling the engine. (d16rice)
get a haynes
Old Feb 4, 2005 | 06:29 PM
d16rice's Avatar
Default Re: Assembling the engine. (dogfood)
I have it, but I'm using ARP head studs (a little different from oem bolts).
Should I just put them by hand (hand-tighten), mount the head and then torque them? Should I put anything on them?
Old Feb 4, 2005 | 06:37 PM
Evs-One's Avatar
Solbros Owns Me
ARP assembly lube or oil will vary the torque specs you should do
Old Feb 4, 2005 | 09:35 PM
Built Beast's Avatar
Default Re: Assembling the engine. (Evs-One)
make sure to tighten(to proper spec) in this order...This is in the manual as well as the Torque specs.
9 5 1 3 7
8 4 2 6 10
Old Feb 4, 2005 | 09:41 PM
v4lu3s's Avatar
RTFM
use the lube that came with the struds and check the paper that came with the studs for proper toque.
Kr4nG
Nov 6, 2009 02:48 AM
gonmaro
Jan 29, 2009 12:05 PM
Jdmb16sir2
Jun 10, 2007 05:50 PM
Used2beAb16
Mar 17, 2004 02:46 AM
b16 matt
Mar 9, 2003 11:32 AM
