JDM ITR Brakes Vs USDM Type R Brakes
Old Sep 20, 2003 | 09:25 PM
Tyteteg119's Avatar
Default JDM ITR Brakes Vs USDM Type R Brakes
Okay I know that 96 spec brakes had Smaller rotors 14" vs the 15" on the 98 Spec (Front)
Question is Which Set of Brakes did the US Type R get? Did the Brakes Change between 97 and 2001?
Seems the US Spec R had the CTR 15 Wheels so I am wondering if the US got the Brakes from the EK9 or DC2?? WHile the 98 Spec DC2 has 16 inch wheels.
Anyone Know the answer? Or can anyone provide a search string that will yeild some results that answer the question at hand. Thanks in advanced.
Old Sep 20, 2003 | 09:32 PM
Mario's Avatar
Default Re: JDM ITR Brakes Vs USDM Type R Brakes (Tyteteg119)
EK9, 98Spec DC2R, USDM DC2R (all); same brakes.
96Spec DC2R, GSR; same brakes different bolt pattern.
Old Sep 21, 2003 | 04:25 AM
Tyteteg119's Avatar
Default Re: JDM ITR Brakes Vs USDM Type R Brakes (Mario)
Thanks
Old Sep 21, 2003 | 07:20 AM
Tsukuba 699's Avatar
I am almost sure the EK9 Brakes are different than the 98 Spec DC2.
Honda OEM has a different PN for them.
Modified by Tsukuba 69 at 9:53 AM 9/21/2003
Old Sep 23, 2003 | 09:20 AM
Tyteteg119's Avatar
Default Re: JDM ITR Brakes Vs USDM Type R Brakes (Tsukuba 69)
Someone said the JDM R's Have larger rotors than the USDM
Old Sep 23, 2003 | 09:26 AM
Ferrell's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyteteg119 &raquo;</TD></TR><TR><TD CLASS="quote">Someone said the JDM R's Have larger rotors than the USDM</TD></TR></TABLE>
JDM axles have 36mm spindle nuts.
Old Sep 23, 2003 | 12:35 PM
GokuSSJ4's Avatar
Default Re: JDM ITR Brakes Vs USDM Type R Brakes (Ferrell)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ferrell &raquo;</TD></TR><TR><TD CLASS="quote">
JDM axles have 36mm spindle nuts.</TD></TR></TABLE>
and what is the size of the usdm itr
Old Sep 23, 2003 | 12:38 PM
TsunamiZC's Avatar
someone told you wrong
Old Sep 30, 2003 | 07:08 AM
Default Re: JDM ITR Brakes Vs USDM Type R Brakes (tsunami_zc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tsunami_zc &raquo;</TD></TR><TR><TD CLASS="quote">
someone told you wrong </TD></TR></TABLE>
Hmmm So the USDM Rotors are 15 inches in the front? Hmmm Must be a tight Fit with those 15 inch rims
Old Sep 30, 2003 | 07:10 AM
Chris N's Avatar
Default Re: JDM ITR Brakes Vs USDM Type R Brakes (Spoon1)
32mm
Old Sep 30, 2003 | 07:41 AM
TsunamiZC's Avatar
Default Re: JDM ITR Brakes Vs USDM Type R Brakes (Tsukuba 699)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tsukuba 699 &raquo;</TD></TR><TR><TD CLASS="quote">
Hmmm So the USDM Rotors are 15 inches in the front? Hmmm Must be a tight Fit with those 15 inch rims</TD></TR></TABLE>
And JDM Rotors are 15 inches .....? NOPE
Old Sep 30, 2003 | 08:51 AM
Pondus's Avatar
The japanese refer to them as 15" rotors as that is the wheelsize needed to clear them, not because they are 15" in dia.
Old Sep 30, 2003 | 09:41 AM
TsunamiZC's Avatar
Default Re: JDM ITR Brakes Vs USDM Type R Brakes (99ITR#3715)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99ITR#3715 &raquo;</TD></TR><TR><TD CLASS="quote">The japanese refer to them as 15" rotors as that is the wheelsize needed to clear them, not because they are 15" in dia. </TD></TR></TABLE>
ahh ....ic .....
Old Sep 30, 2003 | 07:22 PM
Tyteteg119's Avatar
ok I see thanks
Old Sep 30, 2003 | 07:48 PM
EK9 and DC2 (98spec) Use the Same Rotors 45251-sz3-000 However the Calipers are Different 45018(19)-sm5-000 and for the 98spec 45018(19)-ss0-a00
96 spec rotors are different and Calipers are different.
Old Sep 30, 2003 | 11:59 PM
R you serious's Avatar
the integra just got the bigger wheels becuase of the shorter final drive.
Old Oct 1, 2003 | 02:55 AM
1OPTION's Avatar
I was bout to say that.
Old Oct 1, 2003 | 06:02 AM
TsunamiZC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tsukuba 699 &raquo;</TD></TR><TR><TD CLASS="quote">EK9 and DC2 (98spec) Use the Same Rotors 45251-sz3-000 However the Calipers are Different 45018(19)-sm5-000 and for the 98spec 45018(19)-ss0-a00
Really different calipers .....i was not aware of that one ....
What are the differences bewtween the calipers ?
Old Oct 1, 2003 | 07:30 AM
cjames235's Avatar
i know that some kind of jdm type R caliper actually says "Type R" on them
edit: found out they are EP Type R calipers
https://honda-tech.com/zerothread?id=82499
Modified by cjames235 at 11:40 AM 10/1/2003
Old Jan 8, 2008 | 05:11 PM
JDM*BUBBLE's Avatar
Default Re: JDM ITR Brakes Vs USDM Type R Brakes (cjames235)
I heard its hard to get pads and rotors for the 96 type R setup when theyre worn out??
Is this true?? what pads and rotors do you use and where can i get them
Old Jan 8, 2008 | 05:25 PM
I AM WEASEL's Avatar
the 96 spec jdm itr uses the same pads as the usdm gsr - which is the same as all usdm dc tegs non itr. Rotors are a little harder to come by but they are available from fastbrakes as well as hmotors
Prox_Denali199
Mar 24, 2020 08:09 AM
B_Swapped93
Sep 23, 2014 04:17 PM
Street Ghost
Feb 22, 2005 07:55 PM
NINJASPY
Jul 9, 2004 09:57 PM
Cosworth
Apr 21, 2002 04:14 PM
