LS/VTEC
Old Sep 20, 2003 | 12:33 AM
ovrbst's Avatar
Default LS/VTEC
hey guys, i have a b16 currently and am planning to go ls/vtec this winter for next summer
my question is how reliable are they? and what warnings/precautions should i take?
i'll be using a b18a bottom end and a b16a head midly built
any help would be awesome thnx
Old Sep 20, 2003 | 06:23 AM
Fred n J_v2.0's Avatar
Default Re: LS/VTEC (91_civicsi)
Search button, upper right hand corner.
Its your friend.
and just to answer your question, they are only as reliable as the builder builds them. skim parts and shorten life of your motor. be careful and build it up with the proper parts and it will be ok.
i have a ls-vtec set-up already, if your interested, check my sig.
Modified by 95VXFRANK at 10:42 AM 9/20/2003
Old Sep 20, 2003 | 08:58 AM
Hondasaurs's Avatar
You have to use a B series Vtec oil pump and water pump. If you dont, It will not be reliable and I would not rev it past 7k with an LS oil and water pump.
Old Sep 20, 2003 | 08:59 AM
Phatwhippin_CRX's Avatar
Default Re: LS/VTEC (Hondasaurs)
check out my site, i've got a prety good artice on LS-VTEC on there you might want to read....
Old Sep 20, 2003 | 09:06 AM
CHRIS 1.8's Avatar
This will answer all or most of your questions that you may have.
I think this is a good article from IB.
LS/VTEC Motor built the right way.
http://www.importreview.com/reviews/lsvtec.html
Old Sep 20, 2003 | 10:18 AM
ovrbst's Avatar
wow good article chris 1.8 thnx
i alrady have a b16 in my car right now, so i shoudl already have the b16 oil pump and water pump eh? (might be a stupid question)
for ls/vtec how do you think pr3 pistons in the bottom LS block would be?
Old Sep 20, 2003 | 10:29 AM
Hondasaurs's Avatar
Default Re: (91_civicsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91_civicsi &raquo;</TD></TR><TR><TD CLASS="quote">wow good article chris 1.8 thnx
for ls/vtec how do you think pr3 pistons in the bottom LS block would be?</TD></TR></TABLE>
Yes, you have the oil pump and water pump which you will need to swap on the LS block. The PR3 pistons will raise your compression.
Old Sep 20, 2003 | 10:43 AM
ovrbst's Avatar
doing the pr3 piston swap, would be better then im assuming?
Old Sep 20, 2003 | 11:42 AM
Hondasaurs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91_civicsi &raquo;</TD></TR><TR><TD CLASS="quote">doing the pr3 piston swap, would be better then im assuming?
Yes.
PR4 pistion yield a 9.76 compression ratio
PR3 pistions yield a 11.63 compression ratio
http://www.c-speedracing.com/h...c.php
175Shot4Door
May 5, 2009 05:52 AM
WhiteEJCoupe
Sep 15, 2006 11:41 PM
integra_94
Aug 31, 2004 10:25 PM
bens_redeg
Jul 10, 2004 07:11 AM
NuclearB18B
Sep 20, 2002 07:50 AM
