stuck valve in vtec head
Old Sep 19, 2003 | 11:57 AM
jdmlsvtecrx's Avatar
Default stuck valve in vtec head
i was wondering the best way to fix a sticky valve in my b16 head.......have some ideas just was wondering what others think]
thanks
Modified by jdmlsvtecrx at 9:13 PM 9/19/2003
Old Sep 19, 2003 | 02:29 PM
b16supertuner's Avatar
Default Re: stuck valve in vtec head (jdmlsvtecrx)
maybe use an oil with a detergent such as mobil 1 drive clean?
Old Sep 19, 2003 | 03:52 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmlsvtecrx &raquo;</TD></TR><TR><TD CLASS="quote">i was wondering the best way to fix a sticky valve in my b16 head.......have some ideas just was wondering what others think
thanks</TD></TR></TABLE>
Are you sure it's not bent?
Old Sep 19, 2003 | 05:38 PM
pretty sure i just had the valves ground and when i took them out it was fine. now i just new valve seal in and it wouldnt come out......
Old Sep 20, 2003 | 08:15 AM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
Default Re: (jdmlsvtecrx)
try removing the seal (replace again their cheap)...take a hammer and a small punch and tap the valve out the guide..once u have the valve out either have the guide replaced or u can have it reconditioned and cleaned (on the inside) at the machine shop...if u decide to recondition it make sure u have the play checked (valve to guide clearence)
Old Sep 20, 2003 | 04:03 PM
HEAD's Avatar
are you saying you want to get the valve out of head, or the valve is not opening and closing correctly?
I can tell you on the first part, sometimes the keeper groove can develop a ridge around the top and makes it hard to pull through, what I would do is take a fine file and work it around the valve mainly concentrating on the keeper groove don't go crazy with the file or use alot of force and keep repeating this until the valve comes out freely.
were you using the stock retainer or a Ti retainer?
Old Sep 20, 2003 | 04:56 PM
valve will not come out of the head it gets stuck in the valve guide and im using stock retainers
Old Sep 20, 2003 | 05:02 PM
mmuller's Avatar
Mad Scientist
if its bent, its gonna be hard to take it out.cut it
HellaFab
Jun 28, 2011 07:37 AM
Atomic1
Mar 27, 2010 08:57 PM
proj21
Oct 1, 2009 02:40 PM
superfast666
Mar 26, 2008 12:11 PM
1.8EG-T
Dec 14, 2003 02:56 PM
