ENGINE NOISY AFTER TIMMING BELT CHANGE
Old Sep 19, 2003 | 05:07 AM
Sam268's Avatar
Default ENGINE NOISY AFTER TIMMING BELT CHANGE
I got the timming belt change and now the car runs about the same but is really noisy, the mechanic that did it said my valves needs to be adjusted but it wasn't bad before I went in for the belt change. could changing the belt change the gap of my valves... what else should I look at?
Old Sep 19, 2003 | 06:04 AM
GZERO's Avatar
Default Re: ENGINE NOISY AFTER TIMMING BELT CHANGE (Sam268)
what kind of noise? is it like a whistle?
Old Sep 19, 2003 | 07:09 AM
Sam268's Avatar
IS NOT LIKE A WHISLTE. IS LIKE A DEEP GROWLLL... LIKE I PUT IN A AFTER MARKET INTAKE...NOTING HIGH PITCH
Old Sep 19, 2003 | 08:15 AM
pro1342's Avatar
Timing belt is too tight probably.
Old Sep 19, 2003 | 08:39 AM
Slappy's Avatar
Default Re: ENGINE NOISY AFTER TIMMING BELT CHANGE (pro1342)
I agree /\.
Old Sep 19, 2003 | 08:48 AM
NeoGSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pro1342 &raquo;</TD></TR><TR><TD CLASS="quote">Timing belt is too tight probably.</TD></TR></TABLE>
yes...the TIMING belt is probably too tight.....timming belt....sheesh
Old Sep 19, 2003 | 10:31 AM
GZERO's Avatar
Default Re: ENGINE NOISY AFTER TIMMING BELT CHANGE (NeoGSR)
i tought it could be the timming belt, but usually when the timming belt is too tight it makes like a whistle noise, now the kind of noise he describes usually is from the plastic cover touching something.
Just my $.02
Old Sep 19, 2003 | 10:38 AM
99_SH's Avatar
IF the car sounds louder like after you put an intake on, then the dude probably put the intake cam 1 tooth off. Check your cam timing...
Old Sep 19, 2003 | 10:45 AM
Sam268's Avatar
also. when I am at idle gear in netural .. not stepping on anything. my car would do a slight jerk on is only ever 5-6 seconds. man something is really messed up
and the mechcanic that did it is blaming on my valves.
Old Sep 19, 2003 | 12:17 PM
GZERO's Avatar
i can't really say anything, but it doesn't sound as valve out of spec to me, but i could be wrong, did you check the car to be on time?
Old Sep 19, 2003 | 04:38 PM
koco's Avatar
If the timing belt rubs on the cover, it may break. This would be very bad obviously. You might wanna have a look inside the cover and see if it's rubbing on the cover.
Old Sep 20, 2003 | 06:49 AM
Mullac's Avatar
I'd check its timed right.. sounds bad when its a tooth out!
Old Sep 20, 2003 | 09:05 AM
AngryTroll's Avatar
Default Re: (Mullac)
A LOOSE belt will be noisey. It will have a growl (exactly as you described). Is the tech a Honda guy? Did he replace the cam seal? He could have damaged the inner timing cover in an attempt to remove the seal...
Old Sep 20, 2003 | 03:01 PM
PHiZ's Avatar
Default Re: (PIMPASSBEOTCH)
i'd rent a timing gun, and check the timing. Remember to jump the service connector...
-PHiZ
Old Sep 20, 2003 | 06:06 PM
sirminder's Avatar
Default Re: (PHiZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHiZ &raquo;</TD></TR><TR><TD CLASS="quote">i'd rent a timing gun, and check the timing. Remember to jump the service connector</TD></TR></TABLE>
Excuse my ignorance, but why must one jump the service connector when checking the timing? The same service connector used to check for engine codes? I thought you werent supposed to run the engine when that connector was jumped to view the codes?
Old Sep 20, 2003 | 09:27 PM
PHiZ's Avatar
Default Re: (sirminder)
Because your ecu is dynamically advancing/retarding timing while it is running.
So you can't check your "static" timing.
here ya go:
http://www.c-speedracing.com/h...g.php
-PHiZ
Old Sep 20, 2003 | 10:00 PM
koco's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PIMPASSBEOTCH &raquo;</TD></TR><TR><TD CLASS="quote">if they did not use a honda belt it will be noisey also. i always use honda belts for this reason.</TD></TR></TABLE>
This is not true. There are lots of good aftermarket timing belts that run quietly. It can rub on the timing cover if one of the spacers is left out or installed improperly.
JDMtype Eg6
Feb 18, 2007 05:45 AM
obd2gsr
Dec 21, 2002 08:53 PM
$300lude
Dec 15, 2002 09:25 PM
rybred
Dec 7, 2002 09:58 PM
nerdish
Jul 17, 2001 11:22 PM
