pump gas ... compression ...
Old Sep 18, 2003 | 10:10 PM
B18G's Avatar
Default pump gas ... compression ...
We've got 94octane here in Canada ... but lets just say that I'm using 91 tops ...
whats the highest compression that I can run using this gas?
Trying to decide which pistons to use on my LS/VTEC
Old Sep 18, 2003 | 10:18 PM
allmtr's Avatar
Default Re: pump gas ... compression ... (B18G)
i used CTR pistons and a milled head. CR was roughly 12.3:1 and i was on 91 oct. my timing was on a nasty 12 degrees, but it works. Tuning is a good thing.
Old Sep 18, 2003 | 11:11 PM
TECH43 RACING INC.'s Avatar
Default Re: pump gas ... compression ... (allmtr)
i suggest on 91 octane, if you want to run full timing (15/16), dont go over 11.5 to 1.
Old Sep 19, 2003 | 12:19 AM
preluda92's Avatar
Default Re: pump gas ... compression ... (TECH43 RACING INC.)
11.5 to one seems to be the universally accepted any and all pump gas CR.
Old Sep 19, 2003 | 07:01 AM
King Tut33's Avatar
Default Re: pump gas ... compression ... (preluda92)
I run 11.5:1 compression on 93 octane with timing at 17 degrees all day. Just go with the B16a PR3 pistons and forget about worrying.
Old Oct 5, 2003 | 01:32 PM
Rydaddy's Avatar
Default Re: pump gas ... compression ... (King Tut33)
There is a local guy building a 12.5:1 LS/VTEC that will be his DAILY driver on 91 octane. He said the guys building his motor even asked him if he wanted to go 13:1.
Apparently, its all in the tuning.
Old Oct 5, 2003 | 02:13 PM
racerboyb18c1's Avatar
Default Re: pump gas ... compression ... (Rydaddy)
yes u can run that high you will prolly have to run her a lil rich and less timming but its possible , i know some people running 13:1 on 92 and like no timming just to get there cars to the track and then they just run 101 and call her good , just remember before u even think of runnin hard to throw it on a dyno and get a o2 reading and tune from there (holes in pistons are good conversation but not very functional 0
Old Oct 5, 2003 | 02:40 PM
P1mpSlap's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by King Tut33 &raquo;</TD></TR><TR><TD CLASS="quote">I run 11.5:1 compression on 93 octane with timing at 17 degrees all day. Just go with the B16a PR3 pistons and forget about worrying.</TD></TR></TABLE>
11.5:1 was what I've always been told the theoretical max was for 93.
However, I run 12:1 on 93 untuned and it's running fine. No knocking or pinging. Still want to have it tuned though.
Like mentioned above you can run 12:1 or higher on 91 it's just a matter of how you tune it.
Old Oct 5, 2003 | 03:23 PM
Big Teggie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18G &raquo;</TD></TR><TR><TD CLASS="quote">We've got 94octane here in Canada ... but lets just say that I'm using 91 tops ...
Trying to decide which pistons to use on my LS/VTEC </TD></TR></TABLE>
Talk to your tuner, he is what you should use to determine how high you can go.
Old Oct 5, 2003 | 09:27 PM
B18G's Avatar
I checked ur website ...
What skunk 2 program you running? ... My setup will be very similar to yours, and I also have access to 93 octane gas. Ur dyno chart and A/F ratios look mint btw ... nice work
Old Oct 5, 2003 | 09:30 PM
B18G's Avatar
ahhh ... just found out Skunk2 only makes 1 chip for the P28
is this the right chip number?
P30SK489002
Old Oct 8, 2003 | 12:14 AM
skunk2 has more than just one program.
Old Oct 8, 2003 | 05:40 AM
Drag R's Avatar
Old Oct 8, 2003 | 06:07 AM
555R's Avatar
Default Re: pump gas ... compression ... (Drag R)
true all tuning
i have 12.5:1 but it doesnt like pump gas too much...im down at 10-12 degrees depending on weather
I thought full timing was 18 degrees?
I can only run that on 100 plus octanes at the road courses
Old Oct 13, 2003 | 11:50 PM
Default Re: pump gas ... compression ... (555R)
14 degrees is stock
Old Oct 23, 2003 | 01:47 PM
luckypon7's Avatar
Default Re: pump gas ... compression ... (racerboyb18c1)
would 11:5:1 je piston in a b18c1 be just that 11:5:1 even when the weather changes. i'm also deciding to go either 11:3:1 to be on the safe side or 11:5:1 on 93 octane 17, 16 degrees timing and with no piston to valve clearence problems.
sorry to high this thread, but on the same subject.
Old Oct 28, 2003 | 04:10 PM
555R's Avatar
out of curiosity
I run 12.5 with jun 3s and 310 cc injectors
what setup are you guys running
and timing and fuel pressure?
im at 15 degrees with 94 at the moment
with about 47 psi no vacuum
the chipped p28 has a jun prog but i have a mugen and skunk2 proggie also
any thoughts on what worked better for you guys
kidd_drastic
23
Feb 3, 2006 07:59 PM
AllMotorITR
Sep 30, 2002 09:33 PM
itr501
Mar 3, 2002 05:09 PM
Rhetoric
Jan 5, 2002 09:39 PM
C4wrx
Dec 30, 2001 06:30 PM
