Compression, 91 octane and Pinging?
Old Jan 4, 2002 | 06:16 PM
Rhetoric's Avatar
Default Compression, 91 octane and Pinging?
Any of you guys in Ca run a high cr (11.2 or higher) using 91 octane and still get pinging? My comp is at around 11.1-3 and pinging is really bad. I've tried different gasoline 76, Chevron, Shell and with some octane boost and it still bad. Even retarded timing to 12 degrees and it still pings. Im thinking it may be because of the Skunk program? Anyway, any help or suggestions would be helpful. Thanks.
Old Jan 4, 2002 | 06:39 PM
HX_Guy's Avatar
Default Re: Compression, 91 octane and Pinging? (G S R)
What kind of pistons?
With 11.4:1 compression I had no pinging whatso ever on 91 octane and 17 degrees timing. Endyn pistons, but with big cams (lots of overlap which reduces compression)
Ill be at 12:1 CR tomorrow...hopefully it wont ping.
Old Jan 4, 2002 | 11:24 PM
ITR#132's Avatar
Try using your stock ecu or another ecu. 76 has 100 octane, but I know couple of people running about the same compression with no problems. If all else fails keep retarding the timing and visit dynospot.
Rhetoric's Avatar
Default Re: Compression, 91 octane and Pinging? (HX_Guy)
Im at 11.2-3 with Us Itr pistons and a .040 mill. Cams are Skunk's. What kind of gasoline do you use. Also with your new cr what will you use? I dont know why mine is pinging, could it be anything else?
Old Jan 4, 2002 | 11:32 PM
Gump's Avatar
Default Re: Compression, 91 octane and Pinging? (ITR#132)
where can you find 100 octane gas in southern cali?
Old Jan 5, 2002 | 12:24 AM
Mr. Softee's Avatar
Default Re: Compression, 91 octane and Pinging? (xlr8si)
im at about 12:5 compression i think. Well over 250 on a compression tester... I run 10 degrees timing and dont ping. I run type r cams. with the intake cam gear at +1degress and exhaust at +3 degrees
Old Jan 5, 2002 | 09:32 PM
Rhetoric's Avatar
Default Re: Compression, 91 octane and Pinging? (97lstegra)
10 degrees timing? How much power is your car making? What gas (octane) are you using?
Old Jan 5, 2002 | 09:39 PM
B2FiNiTY's Avatar
You can find 100 octane gas at certain 76 stations. I just want to say that 91 octane sucks. Give me back my 92!
kidd_drastic
23
Feb 3, 2006 07:59 PM
92 civic VX B18c
May 23, 2005 10:34 PM
oMek
12
Jun 9, 2004 11:54 AM
AllMotorITR
Sep 30, 2002 09:33 PM
itr501
Mar 3, 2002 05:09 PM
