ferrea valve train??
Old Sep 18, 2003 | 08:53 PM
queez's Avatar
Default ferrea valve train??
hey guys changing all head components in b16a2 to ferrea and going gsr cams. with stock rollerarms.. what will i be able to up my redline to?? any ideas??
Old Sep 18, 2003 | 09:28 PM
92 civic VX B18c's Avatar
HT Black Ops
Default Re: ferrea valve train?? (queez)
I'm interested to know more also, are you asking about the crane/ferrea roller followers? They sure look nice
Old Sep 19, 2003 | 05:11 AM
redlinegsr's Avatar
Default Re: ferrea valve train?? (92 civic VX B18c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92 civic VX B18c &raquo;</TD></TR><TR><TD CLASS="quote">I'm interested to know more also, are you asking about the crane/ferrea roller followers? They sure look nice</TD></TR></TABLE>
Just changing the valves isnt going to increase your redline capability...i assume your replacing the springs and retainers also?? The spring stiffness and retainers is what will determine your redline
Old Sep 19, 2003 | 05:27 AM
queez's Avatar
Default Re: ferrea valve train?? (redlinegsr)
ferrea valve trailn would include. springs retainers locks locators valves all but the roller arms.. i talked to a tech at ferrea and he said with a gsr that had roller arms in it, it redlined at 11krpm.. but like i said i dont have have the roller arms. everything else except the roller arms but with gsr cams.. what can i up the redline to ????
Old Sep 19, 2003 | 06:06 AM
MolecularIntegra's Avatar
What does it matter if you're staying with the GSR cams? Why should they make power past a stock redline?
Old Sep 19, 2003 | 08:36 AM
6SPD_EK's Avatar
Default Re: ferrea valve train?? (MolecularIntegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MolecularIntegra &raquo;</TD></TR><TR><TD CLASS="quote">What does it matter if you're staying with the GSR cams? Why should they make power past a stock redline?</TD></TR></TABLE>
I agree you probably won't make power above 8300-8400 rpm - if that
Old Sep 19, 2003 | 09:35 AM
queez's Avatar
Default Re: ferrea valve train?? (adirondackR)
i'm not saying that i'll make more power cause of the cams, i was just stating what is going in the head setup.. and with a sc61 on my engine, i think the more rpm i can pull out the motor the better it is.. i was asking what possibly the redline would be. since i upgraded pretty much everything
Old Sep 19, 2003 | 10:30 AM
seppuku's Avatar
if you are going to increase you redline...you should probably be upgrading your rods and pistons(lighter and stronger)...otherwise you run the risk of your engine going on melt down because of the increased piston speed.
Old Sep 19, 2003 | 10:54 AM
queez's Avatar
Default Re: (seppuku)
i am in the process of upgrading everything.. cp pistons. pautor rods, upgraded pins for boost+ nitrous, dartgon sleeves.. and alot more..
Old Sep 19, 2003 | 06:18 PM
Eyewitness's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by seppuku &raquo;</TD></TR><TR><TD CLASS="quote">if you are going to increase you redline...you should probably be upgrading your rods and pistons(lighter and stronger)...otherwise you run the risk of your engine going on melt down because of the increased piston speed. </TD></TR></TABLE>
Whoooa...Come back to earth son....
Old Sep 21, 2003 | 06:46 PM
EKFerioHawaii's Avatar
Default Re: (Eyewitness)
hahah oh boy that was classic. *tears*
Old Sep 22, 2003 | 03:19 AM
Muckman's Avatar
Moderator in Chief
Default Re: (queez)
12 replies and not one concrete answer...
dont ya love it?
Old Sep 22, 2003 | 04:52 AM
advanracing62's Avatar
Default Re: (Muckman)
1. it's retarded to rev a stock cam higher than natural red line
2. not sure about the spring rates, or bind- but I'd guess 10k
3. dyno the car with your set up and that will tell youexactly where to rev to
Old Sep 22, 2003 | 04:53 AM
sirminder's Avatar
Dont mean to steal your thread, and I dont have helpful info. But you did bring up the question of changing cams on a B16 head. Well just in case anyone who is thinking of going with that setup, I have some cams for sale ----&gt; https://honda-tech.com/zerothread?id=624386
thegatekeeper14
Aug 30, 2010 03:25 PM
crexer
33
Dec 29, 2006 10:04 PM
jdm ek9 101
11
Sep 4, 2006 06:04 PM
TURBL0W
Nov 9, 2005 01:17 AM
AlphaKennyWun
Feb 7, 2003 05:24 PM
