OH NO reliable honda is messing up
Ive recently been talking about how good my rex has been good to me.. I was driving home to day and a check engine light came ... the car started to sputter shortly afterwards. I was almost home .. less than a mile. I get home and wait on the car to cool down. Then I popped the hood.. I checked the usually. I notice that the radiator was low on coolant.. maybe it was over heating or a leak. So I put some a/f in it. Then I started it up. I notice also why it was there my fans werent comming on. I wait like 10 mins or so b4 I turned it off. I guess maybe that is the cause of it .. Any other ideas? Also, maybe is there a fuse or something else eletrical that can be wrong...
check your fuses,the main relay is a fuse..check your fanswitch,check for leaks,,maybe you need a new head gasket,thermostat,water pump any of those you should check out if you can
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jester »</TD></TR><TR><TD CLASS="quote">heh i dont have anything to check codes.. relay?? got any more info</TD></TR></TABLE>
Your ECU will blink to show the codes. Pull the carpet up on the far passenger side near the glove box & you will see a metal plate on the floor. Once you see teh plate you will see a small "window" for a light to flash. Turn the key to teh accesory position & count how many times the ECU flashes. If you have multiple codes there will be a longer pause in between blinks. You can then search for a list of codes on the net & viola you now know WTF is wrong w/ the car. HTH
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jester »</TD></TR><TR><TD CLASS="quote">I was driving home to day and a check engine light came ... the car started to sputter shortly afterwards</TD></TR></TABLE>
Sounds like your 02 sensor, but pull the carpet back and check like dj said to do.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jester »</TD></TR><TR><TD CLASS="quote">will that also cause my car to have sluggish start then a sudden surge of power?</TD></TR></TABLE>
The O2 sensor can do that, a failing MAP sensor could do it potentially, there could be other issues. Give us the code so that we can help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spaceman »</TD></TR><TR><TD CLASS="quote">you dont have to rip it up(literally)there should be some plug type things holding it down</TD></TR></TABLE>
