I know you guys don't like vtec lights, BUT...Could I get some help please?
Old Sep 18, 2003 | 12:38 PM
slvrcivic97's Avatar
Default I know you guys don't like vtec lights, BUT...Could I get some help please?
I searched and found numerous topics on this. However, here's the deal: Today was raining so I decided to make a vtec light for my sohc vtec. It was very easy to do, but it doesn't work. I have a mini-me swap done and am using a p2p OBD2 v.1 ecu. I have the ground lead from the led wired to a ground, and then the other led lead to the green w/yellow stripe wire that goes into my ecu. (the farthest gray plug or "the big gray plug".) Now when I turn my keys to the accessories position, the led lights up nice and bright until I start it up. Then the led turns off and never comes on even during vtec engagement. I KNOW I WIRED EVERYTHING CORRECTLY. One more thing was that my Check engine light is constantly on while I drive. Could that be why the vtec light never comes on?I'm not trying to ask how to wire a vtec light becuase there are 10000000058943579872984 results to browse in the search, but I would just like to know why mine won't turn on when I hit vtec. I know vtec works too because I can hear it (not my intake either). So, any thoughts?Thanks in advance as I've been scratchin my head raw. j/k
Old Sep 18, 2003 | 01:02 PM
RCautoworks's Avatar
Default Re: I know you guys don't like vtec lights, BUT...Could I get some help please? (slvrcivic97)
The wire for the vtec that goes into your computer changes colors, its orange not green and yellow, not sure if you did your wiring or what not so it might not be, but normally it is.
Old Sep 18, 2003 | 01:23 PM
Default Re: I know you guys don't like vtec lights, BUT...Could I get some help please? (90blackcrx)
really? well, then ooops. How would I go about connecting the green/yellow wire back together than after I take the splice clip off?Here's where I got my directions from:
http://www.hazone.com/hvlight.htm
Old Sep 18, 2003 | 01:45 PM
Now that I think about it, it might be orange on obd0 cars. So now I'm not sure, just try to find an ecu layout and you will know exactly which one it is.
SLOAZZ95
Aug 13, 2004 08:31 AM
Nowellfan2003
22
May 27, 2004 03:58 AM
a1320honda
May 19, 2004 05:53 PM
m3dia_lab
Aug 1, 2003 10:14 AM
you2envious
22
Feb 18, 2002 05:04 AM
