funny noise under hood
Old Sep 17, 2003 | 07:54 PM
social_control's Avatar
Default funny noise under hood
what up h/t...quick question...when i start my car, i hear a funny noise coming from the upper left corner of the engine by the abs system thingy...it sounds like something is vibrating VERY LOUDLY...what the hell is it b/c it's annoying...thanx in advance peps...
-scott
Old Sep 18, 2003 | 04:08 AM
Default Re: funny noise under hood (Seprioth64)
bump
Old Sep 18, 2003 | 10:56 AM
hellooooooooo.....
Old Sep 18, 2003 | 11:45 AM
someone said something to me about an ABS pump?????
Old Sep 18, 2003 | 11:52 AM
jerseybrandon's Avatar
Sounds like ABS pump noise. You should be able to hear it but if its louder than normal, it could be a bad pump. I hope you're still under warranty.
Old Sep 18, 2003 | 11:56 AM
Default Re: (jerseybrandon)
nope...not under any type of warranty...what's the problem with this damn thing...it's kinda noisy!!!
Old Sep 18, 2003 | 01:54 PM
pro1342's Avatar
Normal ABS system noise....pump is pressurizing the system. It should only last about 3 seconds or so. If it lasts any longer, it is low on fluid, or there is a leak in the modulator---very expensive. If you brake to the point that the ABS engages, you will briefly hear the noise again after you stop.
Nhannerds
Nov 1, 2006 10:51 AM
Mike1486
Jan 17, 2005 01:20 PM
mr devious illusions
Aug 7, 2004 11:09 PM
1992gsrb17
Mar 24, 2004 03:00 PM
Mr. Softee
Sep 10, 2001 05:56 PM
