HELP! CRANK PULLY STUCK
Old Sep 18, 2003 | 08:25 AM
zmeli's Avatar
Default HELP! CRANK PULLEY STUCK
WELL I WENT DOWN AND BOUGHT A IMPACT WRENCH RATED AT 625 FT/LBS IN REVERSE(HARBOR FRIGHT "EARTHQUAKE") AND IT WOULD NOT BUDGE. SO I REMOVED THE LITTLE BLACK PLATE FROM BOTTOM OF TRANS BELL HOUSING AND STUCK A HEX TOOL IN THERE TO LOCK FLYWHEEL, USED TWO 10 INCH EXTENSIONS AND BREAKER BAR WITH FLOOR JACK HANDLE ATTACHED AND POP THE BELL HOUSING BROKE!!!!! NOTHING JB WELD CAN'T FIX. DO I
1. GIVE UP TAKE TO DEALER?
2. BUY A PULLEY HOLDER? THOUGHTS? 91 CIVIC DX 1.5
Modified by zmeli at 5:58 PM 9/18/2003
Old Sep 18, 2003 | 08:42 AM
slammed_93_hatch's Avatar
Default Re: HELP! CRANK PULLY STUCK (zmeli)
snap on makes a cool lil tool that goes right in there and holds it in place should have bought that and not wasted money on that impact wrench
Old Sep 18, 2003 | 08:49 AM
zmeli's Avatar
Default Re: HELP! CRANK PULLY STUCK (slammed_93_hatch)
IMPACT WRENCH GOES BACK TONIGHT, DO YOU KNOW IF IT WORKS WITH 91 1.5 THE PULLEY WILL NOT WORK WITH THE 50MM HEX NUT STYLE.
Old Sep 18, 2003 | 09:21 AM
dantastic's Avatar
no need to yell 'round here...
if you cant get the crank to stop, put the car in gear (1st) and have someone step on the brakes, while u use the breaker bar to get the bolt off. that's what i did, and i got the pulley bolt off with a 24" tire iron. try heating the bolt.
Old Sep 18, 2003 | 10:29 AM
Crazydave's Avatar
Default Re: HELP! CRANK PULLY STUCK (dantastic)
Pump the air compressor up more..
I had the same problem.
so i took the cover off my pressure switch on the the compressor..
and cranked on the bolt with the spring to adjust the max pressure on the the tank.
now I can pump >150 psi
140 psi should blast that bolt off
it did in my case
Old Sep 18, 2003 | 10:31 AM
Bumnah's Avatar
Default Re: HELP! CRANK PULLY STUCK (Crazydave)
moroso makes a crank tool. that'll keep the crank from spinning.
here a picture of it holding my ctr n1 pulley
Old Oct 29, 2003 | 08:17 PM
Snail Tuning's Avatar
Default Re: HELP! CRANK PULLY STUCK (Bumnah)
to bad Dseries don;t have that option no hex design in the pulley. i miss by B16a already. Dseries crank pullies
Old Oct 29, 2003 | 08:26 PM
hybridzOr's Avatar
Default Re: HELP! CRANK PULLY STUCK (bmcc72)
Stop yelling....
BoltonGSR
Nov 22, 2006 12:47 PM
Draggin99Si
59
Feb 20, 2005 11:59 AM
xrocket21
Jun 4, 2003 04:35 PM
99YZF
Mar 1, 2003 11:21 AM
Todd00
19
Apr 25, 2002 02:14 AM
