which way does the grooves on the rod caps go?
Old Sep 18, 2003 | 12:58 AM
crx1856's Avatar
Default which way does the grooves on the rod caps go?
do the grooves on the rod caps go on the same side or on oppisit sides? i'm using probe rods.
Old Sep 18, 2003 | 10:33 AM
crx1856's Avatar
Default Re: which way does the grooves on the rod caps go? (crx1856)
i'm talking about the notches on the rods and bearings. do they go on the same side or on opisit sides?
Old Sep 18, 2003 | 11:05 AM
sleepyEK's Avatar
I believe you're refering to the notch that the ear on the bearing goes into. If so, they are opposite eachother.
Old Sep 18, 2003 | 02:37 PM
GZERO's Avatar
Default Re: which way does the grooves on the rod caps go? (sleepyEK)
They all go to the same side, the side oposing the thrust side.
Old Sep 18, 2003 | 03:10 PM
BuddhaSiR's Avatar
Default Re: which way does the grooves on the rod caps go? (GZERO)
its been a while since i've been in a motor but i believe they go on opposite sides of each other.
Old Sep 18, 2003 | 03:33 PM
GZERO's Avatar
Default Re: which way does the grooves on the rod caps go? (BuddhaSiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BuddhaSiR &raquo;</TD></TR><TR><TD CLASS="quote">its been a while since i've been in a motor but i believe they go on opposite sides of each other.</TD></TR></TABLE>
According to the Honda and Toyota Manuals i've read, and the engines i've build, they both go to the same side.
Old Sep 18, 2003 | 07:48 PM
vhd's Avatar
vhd
the bearing tangs on the rod and rod cap goes on the same side. make sure each rod cap is on the correct rod!
Old Sep 18, 2003 | 08:17 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: which way does the grooves on the rod caps go? (vhd)
another one for SAME SIDE
Old Sep 18, 2003 | 08:29 PM
GZERO's Avatar
Default Re: which way does the grooves on the rod caps go? (Emerika)
i can even explain why is like this, since the bearings has one SIDE that supports most of the load after the compression stroke (thrust side) the other side has the mark so you can align the bearings, it doesn't matter because that side won't deal with forces as great as the other side (thrust side).
EG-SIXV-TEC
Jul 5, 2013 05:20 AM
hondatuning1989
Apr 15, 2008 09:10 PM
unknown0001
Jul 3, 2005 07:48 AM
SOHCD16y8
May 21, 2005 12:32 AM
dwilson
Mar 4, 2003 08:13 AM
