Maybe it's the clutch?
Old Sep 17, 2003 | 08:23 PM
Steve90HB's Avatar
Default Maybe it's the clutch?
I'm somewhat new to manual trannys, and never felt a dying clutch or anything.. just curious of what these problems lead to
At high RPM's shifting gears will not lower the RPM... example, first gear to 6000 RPM, switch to 2nd, it's still sitting at 6000 RPM then slowly falls down, and starts to climb again
Another problem, very hard to get into first (when moving) and impossible to get in 2nd without being under 20 MPH???? also reverse LOVES grinding!
any ideas? It's a 91 Si tranny
Old Sep 17, 2003 | 08:59 PM
T4eg's Avatar
Default Re: Maybe it's the clutch? (Steve90HB)
does the clutch feel like its "slipping" and not disengaging right?
Old Sep 18, 2003 | 06:07 AM
michael O's Avatar
reverse gear doesn't have any synchros. Try putting it in 1st then reverse?
Old Sep 18, 2003 | 08:34 AM
pro1342's Avatar
The clutch is slipping or the cable is out of adjustment.
Old Sep 18, 2003 | 12:25 PM
Steve90HB's Avatar
Default Re: (michaelOlson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by michaelOlson &raquo;</TD></TR><TR><TD CLASS="quote">reverse gear doesn't have any synchros. Try putting it in 1st then reverse?</TD></TR></TABLE>
ya that does work, it actually works if I put it in any gear... it just sounds nasty, how do I know if my clutch cable is out of adjustment?
I don't really know what "slipping" feels like, I just started driving a stick
Old Sep 18, 2003 | 01:09 PM
GSRacer1's Avatar
Default Re: (Steve90HB)
I think the easiest way to figure out if you clutch is slipping is to change from 2 to 3rd gear at about 4k rpm and then after you are in the 3rd gear push the gas all the way for about a second, if the rpms climb up fast let go of the clutch and then if you feel a jurk a little bit later as the rpms are coming down then it might be your worn clutch disk.
thats what happened to me.
@Diego
19
Jun 27, 2012 09:31 AM
NGUSPEED
Mar 24, 2010 06:11 PM
ChrisSpade
Apr 22, 2006 10:16 PM
z51LS2
Apr 16, 2006 05:17 PM
Komptech
Mar 29, 2005 07:35 PM
