Rod bearing question
Old Sep 17, 2003 | 08:01 PM
KillerBee18's Avatar
Default Rod bearing question
I have heard from some people that if you use eagle H-beam rods then you use all yellow code rod bearings no mater what the crank code is stamped. Is this true??
Old Sep 17, 2003 | 08:53 PM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
Default Re: Rod bearing question (KillerBee18)
using looser tolerances on the rod bearings reduces friction freeing up some hp, but is recommended more on a race basis not for longevity..(maybe thats where your question came from?)..but i do know that u are supposed to count the big end on the eagles as a #3..and then use the letter on the crank to get the coresponding bearing just like OEM....
Steady R
Aug 7, 2012 10:19 AM
JDM 98 GSR
K Series
Oct 27, 2011 11:09 PM
ilikericedotcom
Mar 21, 2011 08:00 AM
tico
Jan 4, 2011 08:43 PM
MOVE OVER
Dec 25, 2007 08:59 PM
