What is the ELD?
Old Sep 17, 2003 | 10:12 AM
nolimits's Avatar
Default What is the ELD?
97 JDM ITR/ECU. The CEL isn't on, but when checked I'm flashing a Code 20 (ELD). Can anyone fill me in on this a little? I pretty sure my 1100rpm idle is linked to this, but I've never heard of the Electronic Load Detector?! Help!!
Old Sep 17, 2003 | 10:16 AM
mmuller's Avatar
Mad Scientist
Default Re: What is the ELD? (nolimits)
Its under the engine compartment fuse box
Old Sep 17, 2003 | 10:26 AM
rsbad454's Avatar
Default Re: What is the ELD? (mmuller)
ELD is what detects electrical load like when lights and accessories are turned on and draw more load from the alternator.........i believe there is a wire pinned to the ECU that receives this signal to idle the car up.
Old Sep 17, 2003 | 11:11 AM
jerseybrandon's Avatar
Its a common part to fail, several hondas have TSBs about it. Can be pricey too, often come as part of entire fusebox.
Old Sep 17, 2003 | 11:55 AM
nolimits's Avatar
Default Re: What is the ELD? (rsbad454)
From a search it looks like the ecu pinout wire is green/red. I de-pinned this wire when I had AEM EMS from the underdash harness. Now all I have to do is figure out the correct location to push the pin back into!!
EDIT: Found the correct pinout....the code's gone and idle is back to normal!! Now I have to find something else to screw up!
Modified by nolimits at 2:07 PM 9/18/2003
knavishpear
Jun 19, 2018 11:25 AM
jdmdreamz414
42
May 24, 2017 01:39 PM
t3mppa_FIN
Engine Management and Tuning
Oct 20, 2012 06:07 AM
hifi_civic
Oct 5, 2011 11:29 AM
supercharged d
Feb 17, 2010 07:07 PM
