getting block resleeved what questions to ask?
Old Aug 22, 2001 | 09:22 AM
SoloSol's Avatar
Default getting block resleeved what questions to ask?
I was thinking of using Golden Eagle to resleve a b18c block. What questions do I ask them. What should I need to have done to withstand above 20 psi
Old Aug 22, 2001 | 11:28 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: getting block resleeved what questions to ask? (SoloSol)
How much is that going to cost you BTW?
You should ask if they are seperate sleeves, how they are attached, and what the maximum bore you can go to. (If you so desire).
Also, who makes the sleeves, and what they're made of.
As for 20+ PSI, get good quailty parts. Crower rods, JE pistons.... etc......
Let me know what all you want, I may be able to get you a better deal.
Later.
Old Aug 22, 2001 | 02:07 PM
SoloSol's Avatar
I will be going with the largest bore that is commonly used in the b18. 85mm? I dont care what it made of as long as it works. I know that I will need forged pistons and rods, and all that. What else....
Old Aug 23, 2001 | 06:14 PM
earl's Avatar
Ask them if it is better to raise the sleaves .002 above the deck as they do or to O-ring the block.
Old Aug 11, 2004 | 07:32 PM
megotvtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoloSol &raquo;</TD></TR><TR><TD CLASS="quote">I was thinking of using Golden Eagle to resleve a b18c block. What questions do I ask them. What should I need to have done to withstand above 20 psi</TD></TR></TABLE>
i was wondering if different brands of sleeves are stronger than others. if so witch is a good brand that will hold up to atleast 450+whp?
also who does the cheapest yet reliable sleeve job?
blinx9900
Jul 21, 2007 11:50 PM
StrokeMyCrank
Mar 4, 2005 07:56 AM
jeremy.
Sep 6, 2003 07:11 AM
phiberoptik
Aug 27, 2003 10:19 AM
