Home compression tester kit.
Old Sep 16, 2003 | 07:27 PM
5thgenlude101's Avatar
Default Home compression tester kit.
Need help. I need to know how to run a home compression test kit. I called pep boys and they said you remove one of the spark plugs and plug it into that and crank the car or something. I dont really understand what they mean. can someone plz help out? I need to know by thursday because i'm going to do a compression test on a car I might possibly buy. its a 1999 lude 5 speed with a JRSC on it. has 57k miles total. wanna make sure the engine is in ok condition before I buy. Thanks! - Matt
Old Sep 16, 2003 | 10:13 PM
98LudeSH's Avatar
Default Re: Home compression tester kit. (5thgenlude101)
ude its pretty easy.. just take out a spark plug, screw in the compression tester... and crank the engine a few times, helps to have 2 people, that way one can watch the guage on the compression tester and the other can crank the car. when the needle on the guage stops goin up, stop crnakin...repeat on all the other spark plug holes... simple
Old Sep 16, 2003 | 10:34 PM
KW2000's Avatar
Default Re: Home compression tester kit. (98LudeSH)
make sure u unplug the coil wire before u crank the engine
Old Sep 17, 2003 | 02:40 AM
Behan's Avatar
Default Re: Home compression tester kit. (KW93LUDE)
also pull the fuse for your fuel pump and release the pressure in the system.
DxBurnoutKing
May 11, 2013 01:02 AM
danny98r
May 18, 2005 12:31 PM
zracer240
Apr 24, 2005 08:35 AM
92TEGsrSC
Apr 13, 2004 12:52 PM
Toda Built
May 13, 2003 04:42 PM
