Will the JDM 4.7 Final drive work with a stock 99-00 si diff?
I ordered a jdm final drive and need to know if it will work with the stock diff in the 99-00 si tranny. Thanks
ok...need more input
Brad at RLZ engineering: stock diff ok
Mackspeed 616: stock ok
chad: need integ diff
guy above: need integ diff
ive heard both sides from others as well
SGT aka steve sakai says it needs one as well. guess thats that, now that 2 very reliable sources have said so
I just looked at 2 final drive ring gears I have. One is out of a 00 SI tranny, and the other from a 01 ITR tranny.
The ID of the ring gear is different on each. (rough measurments)
00 SI= 4.25"
01 ITR= 4.50"
I will post some pics I took later on.
00 SI= 4.25"
01 ITR= 4.50"
gsr/itr diffs are one size and b16 diffs are differant... the 4. 7 will only fit on a itr or gsr sized diff... iv taken apart enough tranny's to be able to say im 110% sure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Teggie »</TD></TR><TR><TD CLASS="quote">I just looked at 2 final drive ring gears I have. One is out of a 00 SI tranny, and the other from a 01 ITR tranny.
00 SI= 4.25"
01 ITR= 4.50"
I will post some pics I took later on.</TD></TR></TABLE>
right on the money. with pics to boot, nice one!
Now I guess you gotta buy a used ITR LSD !!!!!!!!! thats good for ya!
00 SI= 4.25"
01 ITR= 4.50"
right on the money. with pics to boot, nice one!Now I guess you gotta buy a used ITR LSD !!!!!!!!! thats good for ya!
i already bought a gsr diff gear. couldnt afford the itr lsd at the moment because ive spent over $2000 in the last 3 weeks on my car
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by owen_the_soyboy »</TD></TR><TR><TD CLASS="quote">
Just trying to help
right on the money. with pics to boot, nice one!</TD></TR></TABLE>
Just trying to help
ok, now we need this cleared up: ive got the gsr diff. can i use the si diff bearings? and what about shimming
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller »</TD></TR><TR><TD CLASS="quote">99-00 s4c tranny's have the bigger ring gear and diff., just like the gsr/itr.
so yes it will fit</TD></TR></TABLE>
yep!
The hydro Y21 b16a tranny is the one that uses teh smaller diff/fd ring gear.
[E D I T]
You sure those are pics of a 99+ Si fd ring gear and not a Y21 ?
You can fully tell the diff wont fit by from the Si picture by the spacing of the holes to the ITR diff mounting holes.
yep!
[E D I T]
Katman, the picture of the SI ring gear is from a 99-00 SI B16 tranny.
I also just took a diff out of another 99-00 SI tranny and it is the same size as the one in the picture.
Both b16 ring gears I have are smaller and have different bolt spacing than my ITR and GSR's I have sitting around.
ive got the gsr diff and everything is going in next weekend
Twenty36_1
Jul 13, 2004 09:24 PM
flyrice
May 13, 2004 01:11 PM
red civic standard
Sep 18, 2003 08:02 AM
B18C5-EH2
40
Feb 23, 2002 05:02 PM
