question on itr swap in gsr
Old Sep 15, 2003 | 10:22 PM
sohc it to me's Avatar
Default question on itr swap in gsr
for a jdm type r swap in a 95 integra gsr can i use my gsr wiring for the motor and use my gsr ecu and eventually have it reprogrammed, shouldnt the gsr ecu run fine with the motor its sorta like putting high compression pistons, slightly ported head, and skunk 2 manifold on gsr engine. any help or tips on this swap would be appreciated
Old Sep 16, 2003 | 01:09 AM
Katman's Avatar
Default Re: question on itr swap in gsr (95blkgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95blkgsr &raquo;</TD></TR><TR><TD CLASS="quote">for a jdm type r swap in a 95 integra gsr can i use my gsr wiring for the motor and use my gsr ecu and eventually have it reprogrammed,
-- yes you can AND you will also need use these parts off your GSR engine as well in order for everything electrical to be pnp (plug n play):
- distributor
- injectors
- alternator
- vtec solenoid (JDM ITR engines don't use a vtec pressure switch, which you need).
-- heh, yes its sortta like that. don't forget about the transmission, thats one of the bigger perks about a type-R engine.
Old Sep 16, 2003 | 08:42 AM
Default Re: question on itr swap in gsr (Katman)
so the electrical will be plug n play by using my gsr distributor, injectors, alternator, and vtec colenoid. So my ecu and wiring will then run the engine fine, eventually i can reprogram my gsr ecu to run the engine like a type R? such as redline and other specs.
Thanks for your help Katman
Old Sep 16, 2003 | 10:14 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95blkgsr &raquo;</TD></TR><TR><TD CLASS="quote">so the electrical will be plug n play by using my gsr distributor, injectors, alternator, and vtec colenoid. So my ecu and wiring will then run the engine fine, eventually i can reprogram my gsr ecu to run the engine like a type R? such as redline and other specs.
Thanks for your help Katman </TD></TR></TABLE>
that's right & your welcome.
forbangerhero
Oct 27, 2010 12:32 AM
canospeed200
May 22, 2009 10:37 AM
speedlabx2005
Mar 8, 2006 09:32 AM
sohc it to me
Sep 16, 2003 10:28 AM
C Squared
Jul 23, 2002 11:44 AM
