B18C5 into a 99 GSR ..need some swap info
Old Sep 15, 2003 | 12:27 PM
nousername's Avatar
Default B18C5 into a 99 GSR ..need some swap info
Is this a direct bolt in? What do I need if anything to make this swap happen.
The motor: B18C5 (1998)
The car: 99 GSR
Let me know. Are the axles different? Motor Mounts? Wiring Harness? Shift Linkage?
I heard this was a direct bolt in, but didn't get it from a trust worthy source...let me know otherwise.
Take care,
Old Sep 15, 2003 | 05:38 PM
jkbrand's Avatar
Default Re: B18C5 into a 99 GSR ..need some swap info (nousername)
Your source WAS untrustworthy.....can't be done, but I'll take the B18C5 off your hands for you
Old Sep 15, 2003 | 05:41 PM
toolowsol's Avatar
Default Re: B18C5 into a 99 GSR ..need some swap info (jkbrand)
bah, its all plug and play man, same axles, same mounts, same wiring (except b18c5 doesnt' have AIB....
Old Sep 15, 2003 | 06:15 PM
VTECVillain's Avatar
Just transfer your GSR engine harness onto the ITR motor and it will be plug and play. Replace any missing parts (if any) with ones from your GSR. There will be no extra wiring or anything, should be a direct bolt in and all plug and play, it can't get any easier than that!
Old Sep 15, 2003 | 07:03 PM
poison's Avatar
Default Re: B18C5 into a 99 GSR ..need some swap info (VTECVillain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain &raquo;</TD></TR><TR><TD CLASS="quote">Just transfer your GSR engine harness onto the ITR motor and it will be plug and play. Replace any missing parts (if any) with ones from your GSR. There will be no extra wiring or anything, should be a direct bolt in and all plug and play, it can't get any easier than that! </TD></TR></TABLE>
Yep, I have done this exact swap and all is plug and play...
However, what I did is I used the IAT and fuel injector wiring from the ITR engine harness and cleaned up the engine harness a little bit since the IAT, IACV and such sit on the BACK of the Intake Manifold on the B18C1, whereas the C5 they sit in the front of the Intake Manifold.
That`s all you might have to mess with. Other than that, plug and play.
S13Morgan
Dec 10, 2010 05:53 AM
killerB16A
Apr 3, 2007 10:02 PM
pwrofdrm
Mar 2, 2004 05:33 AM
stickercuttingcom
13
Dec 22, 2003 05:46 PM
GoodGasMileage
Jun 9, 2003 06:12 PM
