Spoon B16B stroker kit into a B16A?
Old Sep 15, 2003 | 10:51 AM
Yusuke's Avatar
Default Spoon B16B stroker kit into a B16A?
I'm interested in stroking my B16A to a 1.8L using the Spoon Sports stroker kit. My question is... will this kit that is intended for a B16B fit perfectly into a B16A? I have researched the differences between B16A and B motors and apparently the only things that change are valvetrain, cams, pistons, P&P head and Intake manifold/throttle. Has anyone ever tried this conversion yet?
Old Sep 15, 2003 | 10:54 AM
mmuller's Avatar
Mad Scientist
Default Re: Spoon B16B stroker kit into a B16A? (Yusuke)
no it wont be fine, b16a block is shorter
Old Sep 15, 2003 | 12:09 PM
Filliam H. Muffman's Avatar
Default Re: Spoon B16B stroker kit into a B16A? (mmuller)
b16b = destroked b18c5. so no.
Old Sep 15, 2003 | 05:24 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Yusuke &raquo;</TD></TR><TR><TD CLASS="quote">I'm interested in stroking my B16A to a 1.8L using the Spoon Sports stroker kit. My question is... will this kit that is intended for a B16B fit perfectly into a B16A? I have researched the differences between B16A and B motors and apparently the only things that change are valvetrain, cams, pistons, P&P head and Intake manifold/throttle. Has anyone ever tried this conversion yet? </TD></TR></TABLE>
not only is the B16 deck height (7mm) shorter than a B16B/P72 block, B18C rods are too long (1) so you wouldn't be able to use the stroker kit rods at all; you'd have to get custom rods made for sure. (2) The crank journals on a B18C crank are not as wide as that of a B16's crank journals; you'd have to get machine work to fix that. (3) Your rod ratio will be on the crappy side, if you didn't know. (4) You're a lucky (rich) man if you can still find a Spoon 1.8L B16B stroker kit (they discontinued them a while ago).
Old Sep 16, 2003 | 07:22 AM
Yusuke's Avatar
Default Re: Spoon B16B stroker kit into a B16A? (Katman)
Thanks for the info. Learning as I go.
Old Sep 16, 2003 | 11:29 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Yusuke &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the info. Learning as I go.</TD></TR></TABLE>
cool beanz.
davehewitson
Jul 21, 2005 09:40 AM
disamis
Mar 29, 2003 08:13 PM
kingfrost
Mar 4, 2003 06:23 PM
ATS*Mark
21
Feb 9, 2003 08:12 AM
DANO626
Aug 19, 2002 01:59 PM
