spoon stroker kit for b16b
Re: spoon stroker kit for b16b (TURSpoonEK)
because..a b16b is not a b16a. a b16b block is virtually a destroked b18c block.
b16b and b16a blocks are not the same
and fyi: you could find a 1.8 block for cheaper then all the drama of stroking a b16a to 1.8.
Buying a SPOON balanced B18C-R short block may save u a bit hassle on installing the stroker kit. And a better idea if there is no experienced technician in your area.
They used to make B16A 1800cc kit but it has discontinued long time ago. I think TODA & JUN are the companies that still offering 1800cc kit for B16A.
For further info u can go to http://www.aj-racing.com http://www.ipsracing.com or http://www.randdmotorsports.com
So basically no one answered his basic question of will it work in a b16a block.
BTW it is not easy to find gsr short blocks. I think I would rather spend $1700, and buy a type R short block from Acura.
Looks like I failed to answer the initial question as well...
Re: spoon stroker kit for b16b (b20bastard)
i dont know much about the b16 and i have 2 questions. will a b18 block bolt up the b16a head with no modifications? and is head for the b16b the same as the head for the b18c5?
New User
not sure about the spoon one but i have the toda stroker kit in my ek. I was not happy with it at first until we installed the hondata. Going from stock ecu to the hondata made a world of difference with my settup. If i was starting from scratch with no motor this would not be the way that i would go but if you have a b16 and would like major gains NA then i would stroke it again.(that didn't sound to good)
Re: spoon stroker kit for b16b (euclid)
My friend did compare both of the head and he said there is minor difference except the intake cams. So does the ITR & CTR intake manifold.
Guest
Posts: n/a
i think all b series parts are interchangeable...and if u compare a b16b block and b16a block. they are totally different...i asked this question a long while back. b16b and b18c5 are near identical if not identical in terms of block
here is the answer you have been looking for.
NO. it will not fit into a B16A. Would not bother machining it either. waste of time. find yourself a B18 or better still keep the B16 and put some EK9 pistons or Toda pistons on it to raise compression
OG triple OG
Re: spoon stroker kit for b16b (ahki)
hey DMS Racing , could you email me the complete specs on intake and exhaust spoon cams and ctr cams , that would be much appreciated
Dancing is Forbidden
09-19-2002 10:10 AM
