Old Apr 1, 2015, 09:24 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior Guides
Print Wikipost
why are my headlights so dim?!?!?
Old Sep 14, 2003 | 05:43 PM
DRxCIVIC's Avatar
Default why are my headlights so dim?!?!?
Yea I was just wondering why my headlights are so dim?? i've changed out the bulbs but still no improvement. Then I tried adjusting them, and still nothing. I looked at the wires and they seem to have been kind of melted. How could I fix this so I would be able to see at night!!! THanks!!
Old Sep 14, 2003 | 06:03 PM
Patch's Avatar
Default Re: why are my headlights so dim?!?!? (DRxCIVIC)
Is your alternator in proper working condition?
Old Sep 14, 2003 | 06:40 PM
DRxCIVIC's Avatar
Default Re: why are my headlights so dim?!?!? (Patch)
yea its fine.... ne one else?!?!
Old Sep 14, 2003 | 06:48 PM
Patch's Avatar
http://www.fourthgenhatch.com/9005.html
Old Sep 14, 2003 | 07:01 PM
dankbudz11357's Avatar
i've heard that it could be the grounding. that's what i've heard.
Old Sep 14, 2003 | 07:06 PM
keebler65's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Patch &raquo;</TD></TR><TR><TD CLASS="quote">http://www.fourthgenhatch.com/9005.html</TD></TR></TABLE>
yeah the stock 9006 bulbs are a lower output than the 9005 and they also have the tips painted which reduces the final output even greater. with my stock bulbs, my lights always looked yellow and dim but when i put in the 9005 bulbs, they were a really clean white and lit up the road much more. i'd highly recommend the conversion. it doesnt take any more than $10 and 10 minutes of time
Old Sep 14, 2003 | 07:34 PM
4crx4me's Avatar
Default Re: why are my headlights so dim?!?!? (dankbudz11357)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dankbudz11357 &raquo;</TD></TR><TR><TD CLASS="quote">i've heard that it could be the grounding. that's what i've heard.</TD></TR></TABLE>
If ONLY your headlights are dim and everything else is working correctly.
You have a bad or loose ground somewhere.
Old Sep 14, 2003 | 07:48 PM
Swift's Avatar
Default Re: why are my headlights so dim?!?!? (keebler65)
That is some great info. I just wanted to say thanks b/c I will be doing the conversion this weekend.
Old Sep 21, 2003 | 12:52 PM
DRxCIVIC's Avatar
Default Re: why are my headlights so dim?!?!? (4crx4me)
where could i find this negative wire at??
Old Sep 21, 2003 | 01:27 PM
4crx4me's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DRxCIVIC &raquo;</TD></TR><TR><TD CLASS="quote">where could i find this negative wire at?? </TD></TR></TABLE>
1st make sure the bulbs are NEW, and ALL the plugs and connections are tight. Then check your grounds there are a few throughtout the engine bay. Or you trace the negative wire back from the headlight plug youself to the it's ground. If you have a helms it will make the whole thing alot easier.
HTH
hcivic99
Jan 28, 2009 09:34 AM
sole
33
Mar 18, 2006 12:31 PM
..::91TEG-G2::..
Apr 30, 2005 06:27 PM
Commodore
May 13, 2003 07:16 AM
