pulling ecu codes on 97 accord??? how to please..
Old Sep 13, 2003 | 06:29 PM
TurboBumblBee's Avatar
Default pulling ecu codes on 97 accord??? how to please..
hey everyone.. never worked on many accords im a fan of civics and integras.. anyways got a friend of mine that is a girl and she has no clue why her CEL is on.. i went to look for the harness where it is on civics and integras and it wasnt there.. where do i short the service connector to get the flashing CEL?? is it right on the ecu under the floorboard or somewhere else?? thanks
Old Sep 13, 2003 | 08:26 PM
Default Re: pulling ecu codes on 97 accord??? how to please.. (Hybrid95CivicEX)
back to the top.. need some help from someone.. she wants me to look at the car agian tomorrow after work
Old Sep 14, 2003 | 06:23 AM
does no one get CEL on there accords???
Old Sep 14, 2003 | 08:10 AM
89_LXi's Avatar
'97 is OBD-II, so you won't be able to pull the OBD-II codes without a scan tool, which will run you about $150 or so. However you can pull the basic 2 digit codes using a jumper wire. Pull the ashtray out and you'll see the 16 pin connector in there, and there will also be a 2 wire connector attached to it. Pull that 2 wire connector out, jump the 2 wires with a jumper, and turn the key to 'on'. If there's any basic codes the CEL will flash out the code(s). If you get nothing, then you'll either have to buy a scan tool or take it to someone
Old Sep 14, 2003 | 04:24 PM
Default Re: pulling ecu codes on 97 accord??? how to please.. (89_LXi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89_LXi &raquo;</TD></TR><TR><TD CLASS="quote">'97 is OBD-II, so you won't be able to pull the OBD-II codes without a scan tool, which will run you about $150 or so. However you can pull the basic 2 digit codes using a jumper wire. Pull the ashtray out and you'll see the 16 pin connector in there, and there will also be a 2 wire connector attached to it. Pull that 2 wire connector out, jump the 2 wires with a jumper, and turn the key to 'on'. If there's any basic codes the CEL will flash out the code(s). If you get nothing, then you'll either have to buy a scan tool or take it to someone</TD></TR></TABLE>
sweet.. thanks man.. im gonna take a look at her car tomorrow.. all i need to find is the 2 digit codes unless she wants me to get it scanned at a dealership for her..
Old Sep 15, 2003 | 12:11 AM
im_the_teacher's Avatar
wow u go alot of trouble for this girl. she must be cute
if she cute,,, i can help her
Old Sep 15, 2003 | 02:19 AM
Default Re: pulling ecu codes on 97 accord??? how to please.. (im_the_teacher)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by im_the_teacher &raquo;</TD></TR><TR><TD CLASS="quote">wow u go alot of trouble for this girl. she must be cute
if she cute,,, i can help her</TD></TR></TABLE>
lol its not much trouble.. she is a good friend of mine and is cute and recently we have been talkin more so something might happen in the future
Old Sep 15, 2003 | 01:48 PM
jaader's Avatar
does anyone have the OBD2 codes interpreted into a 2 digit code?
If There is such a list I would like to have it for future use.
Regards
Old Sep 16, 2003 | 07:19 PM
where is this 2 wire connector?? i was working a 97 accord today at work and i did NOT see behind the ashtray! did i miss it or something, is it stuck back under there?? i did see the obd2 connector but no 2 pin harness to short out like on my civic thanks
Old Sep 16, 2003 | 08:47 PM
SummerTaz's Avatar
Default Re: pulling ecu codes on 97 accord??? how to please.. (jaader)
Don't if that's what you're talking about but I think it could help
Deciphering the code requires reading the light sequences. When the car is in the ON position, the check engine light emits two different flashes; a long extended flash means 10, and a rapid flash means 1. So, one long flash, another long flash, followed by 3 quick flash stands for...................23! Equipped with that information, here are the codes for the '92-'00 Honda and '94-'00 Acura.
0 ECU
1 Oxygen Content
3 Map Sensor
4 Crank Angle Sensor
5 Map Sensor
6 Coolent Temperature
7 Throttle Angle
8 TDC Position
9 No 1 Cylinder Position
10 Intake Air Temperature
63 Intake Air Temperature
12 Exhaust Gas Recirculation System
13 Atmosphere Pressure
14 Electronic Air Control
15 Ignition Output Signal
16 Fuel Injector
17 Vehicle Speed Sensor
20 Electronic Load Detector
21 VTEC Solenoid Valve (1.8L GSR)
22 VTEC Oil Pressure Switch (1.8L GSR)
23 Knock Sensor
30 TCM Signal A
31 TCM Signal B
41 O-2 Sensor Heater
43 Fuel Supply System
45 System Too Rich or Too Lean
48 Primary Heated O-2 Sensor
54 Crankshaft Speed Fluctuation Sensor
61 Primary O-2 Sensor Circuit
63 Secondary O-2 Sensor Circuit
67 Catalyst System
70 Automatic Transaxle
71-74 Random Misfire
80 Exhaust Gas Recirculation
86 Engine Coolant Temperature Circuit
90 Evaporative Emission Control System Leak Detected
91 Fuel Tank Pressure Circuit
92 Evaporative Emission Control System Insufficient
Old Sep 16, 2003 | 09:17 PM
89_LXi's Avatar
Default Re: pulling ecu codes on 97 accord??? how to please.. (SummerTaz)
Maybe this picture will help some.... (I know it's blurry as f**k, but you can kinda make out the pictures)
I can't speak from personal experience, but it looks as if this little connector is actually part of what makes up the 16 pin OBD-II connector, along with another plug. You have to actually take the diagnostic plug out and unplug this from the back of that plug.
Old Sep 17, 2003 | 08:23 PM
anyone else know what plugs need to shorted out to get the darn codes?? i know what the codes are they are the same a civic but i dont know who to find out what codes they are.. ive worked on and swapped several motors into civics and integras and never had a problem geting the CEL to flash!! HELP
godlymen
Nov 23, 2016 11:18 AM
AbitAvenger
Mar 1, 2011 06:49 PM
ntrider
15
May 29, 2005 01:53 AM
Ricey McRicerton
Jun 18, 2003 11:55 AM
VTEC-DA
Nov 29, 2002 01:27 PM
