how must boost can i safely run,,with stock internals,,with all my mods??
u can read all my mods in my sig,,right now,,im runnin 8psi,,but i wanna rus as much boost as i can,,and have it run safe,
we dyno tune my car,,so the tuning would b done right,,and i think i have enough to support more boost
is there anything i should do ,,before i up the boost??
thanks mike
thanks mike
From: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
From what I have been told, no more than 10psi of you want it to last.
throw a blockguard in there, get a nice tune, and run 20psi all day. I did for a year and a half on a t3/t04B/440cc/hondata/stock motor setup...drove her to work everyday, too.
shami
shami
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94goldjungsr »</TD></TR><TR><TD CLASS="quote">if your a/f ratio is 12:1 and you dont have a lot of timing 14psi will be easy.</TD></TR></TABLE>
How many degrees though should he back off on timing per psi? with 12:1 a/f ratio?
just do 1 # to be safe and use some toulene in your mixture. you can add a efw more degrees in the last boost column but the gains wont be much.
so,,u would say that im underboosting right now,,,,only runnin 8psi???
i am gonna look into cams,,and some forged stuff in a lil bit,,
but just wanted to see what i can run with what i have now
i didnt wanna blow it up,,and have to spend alot more money then i would of,,just using moeny to build the motor,,to handle more psi
i think im gonna try 10 psi
thanks mike
thanks mike
Yep seen it done before....
The comment about 10psi which engine are you refering to?
each engine is different, 10psi on a sohc d15 is a lot harder then 10psi on a b18c, then add tuning into it's a whole new ball game...it soundws as though he's got the tuning dept in check
