obd1 LS in a CRX (wont start) NEED HELP my only car ^_^
Old Sep 12, 2003 | 10:08 AM
projektCRX's Avatar
Default obd1 LS in a CRX (wont start) NEED HELP my only car ^_^
k... i have an obd1 LS, using obd0 LS ecu, using 89 CRX si harness...getting fuel, getting spark, fires are correct order, have compression...USING obd1 distrib.
it cranks, starts, and dies.... i have a few questions...
i believe im using the wrong distributor...which one should i be using? at first i thought obd0 LS distrib. but the connector is a square with 6 pins, the crx harness is circle with 7 pins. and the holes dont line up to bolt....WHICH DISTRIB. SHOULD I BE USING???
the other is which map sensor should i be using. should u just plug into the Ls map sesonr on the intake manifold, or should i remove the the LS sensor, tap the vacume hole and use the CRX map sensor on the firewall and run the vaccum line to the tap?
what distrib? and which MAP sensor?, if u can please help... post reply, emial...call 2063832646
THANKS - erwin
Old Sep 12, 2003 | 10:27 AM
Doodoo's Avatar
Default Re: obd1 LS in a CRX (wont start) NEED HELP my only car ^_^ (projektEF9)
You should be using a 90-91 LS distributor. It plugs right in. The OBD-1 distributor will not work unless you change the ECU to OBD-1. Keep it though just in case.
Plug in the map sensor on top of the throttle body and you should be set.
Old Sep 13, 2003 | 04:30 AM
Mattamotor's Avatar
You have to use the 90-91 integra intjector to.
And you must use the 90-91 LS assembly that has the map sensor,purge release, and fuel pressure cut-of soliniod mounted to one braket. The Si has all of that but fuel pressure cut-of soliniod so you must run one wire back to pin A10 on the ecu to wire it. You car will run with out doing this but it will be rick as all hell and bog at lower rpms.
I just swap a 92 B18A1 into my 90 Civic Si so i kinda of went though the same thing you goin though.
Old Sep 13, 2003 | 07:59 PM
IntegraXSi's Avatar
All you need is a 90-91 Ls Dist.. And the holes do line up I think the one you thought was an ODD-O was not and ls one.. My bro has been running a B18B in his car for over a year now you just have to have The OBD-O dist and Fuel injectors the ones out of your CRX will be fine... Also make sure to use the stock MAP on your firewall not the one on the T/B.
Old Sep 15, 2003 | 10:25 PM
projektCRX's Avatar
Default Re: (IntegraXSi)
havent been online the whole weekend, just got back form vegas to make some money to buy a distrib.. and a vaction as well, but yea thanks fer replying homie....i also thought i got jacked on that distrib i bought... didnt spend much on it but. man.. now the problem is finding one.. i could have one shipped outta montreal for brand new but its like 300 bucks.. but yeah...thanks again...oh yah since im using the MAP sensor on the firewall.. do i run that hose to the hole the the OBD-1 MAP sensor is over?
Old Sep 16, 2003 | 04:31 AM
IntegraXSi's Avatar
I would that hole is a hole in the tb I would plug it some how...
iBrandon
Apr 16, 2007 05:52 PM
stackz
Sep 29, 2006 11:11 AM
slows2k
Mar 3, 2006 02:12 AM
KingElli
Aug 4, 2005 09:11 AM
XpodX
Dec 4, 2004 10:08 AM
