How do I adjust my IDLE?
Old Aug 20, 2001 | 09:30 PM
wantmorepower's Avatar
New User
Default How do I adjust my IDLE?
Do you guys know how to adjust idle on a B18C1? I think there is a screw on the throttle body which needs to be turned, however I don’t know if it is clockwise or anti-clock wise. Please help.
Old Aug 21, 2001 | 12:00 AM
Halo's Avatar
Default Re: How do I adjust my IDLE? (wantmorepower)
there is a idle adjustment screw on your TB
Old Aug 21, 2001 | 12:40 AM
BoM's Avatar
BoM
Default Re: How do I adjust my IDLE? (Halo)
also tightening ur throttle cable would raise it...cause the things stretched...if u do it too much then it'll be off...
Old Aug 21, 2001 | 08:21 AM
96IntegraLS4DR's Avatar
I did it to my G2.
According to Helm, you need to pull VAIC (sp?) plug first.
Yeah, turn screw counterclockwise to raise idle.
Old Aug 21, 2001 | 11:16 AM
wickedxbo1's Avatar
New User
Default Re: How do I adjust my IDLE? (96IntegraLS4DR)
tighten your throttle cable and then if that doesnt work, adjust your tb.
Old Aug 21, 2001 | 12:08 PM
Go Mifune's Avatar
New User
ah...um...i don't thinkyou should adjust idle using the throttle cable adj. you want that up to spec which i think is 10-12mm deflection. then use the screw to adjust idle speed. (NOT the throttle stop screw!)
my helms describes that procedure where you disconnect the iac (idle air control valve) and set the idle which gives a low number like 480 or something then you plug it back in and you get 750ish but i've never seen anyone actually do that. they just turn the screw. which way? just try it...you'll figure it out pretty quick. hth.
asocallocal
Sep 23, 2010 06:20 PM
itzyaboyzeem03
Sep 30, 2009 04:11 PM
emooheo
Mar 23, 2007 02:34 PM
BDogggUT34
Jan 18, 2005 04:05 PM
91_hatch_si
Feb 3, 2003 10:24 PM
