Junkyard turbo suggestions
Old Sep 10, 2003 | 04:16 PM
model x's Avatar
Default Junkyard turbo suggestions
I've got a b16a and I do a bit of AutoX and I'd like roughly 250whp minimum.
I was planning on using a T3 from a ford t-bird or Merkur.
Can you suggest another turbo that would fit my needs and be in the same price range?
What about a T3 from a saab or Chrysler?
Old Sep 10, 2003 | 05:23 PM
b16ahybrid's Avatar
Default Re: Junkyard turbo suggestions (model x)
Whats your price range?
Go to cheapturbo.com to get a good price on a new t3t4 (.57 trim .63 a/r works good for me)
You'll have a hard time making 250+ whp with a turbo from a saab or chrysler, trust me I had one.
It's just to small (.42 cold side .48 hot)
Old Sep 10, 2003 | 05:26 PM
b16ahybrid's Avatar
Default Re: Junkyard turbo suggestions (b16ahybrid)
maybe even a little smaller like a .48 a/r .50 trim may suit you a little better because it will spool a little quicker to get you the power you need down low.
Old Sep 10, 2003 | 05:29 PM
stackz's Avatar
at the jetties fishin'
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by model x &raquo;</TD></TR><TR><TD CLASS="quote">I've got a b16a and I do a bit of AutoX and I'd like roughly 250whp minimum.
What about a T3 from a saab or Chrysler?</TD></TR></TABLE>
stay with the .60 trim T3 from the ford/merkur camp....the one on the saabs is just a .48 trim and will max spool out long before the power curve of your engine..
the T3 on the chryslers use an offset pattern and are even harder to use and have .48 trim also....
Old Sep 10, 2003 | 05:40 PM
spock_rocker's Avatar
memoryFAB.com representative
Default Re: Junkyard turbo suggestions (stackz)
i have an old saab T3 turbo with a .48 trim... will that be good for a D16??
Old Sep 17, 2003 | 11:14 AM
stackz's Avatar
Community Builder
Default Re: Junkyard turbo suggestions (spock_rocker)
yep, only difference between the saab/volvo T3's and the "super60" T3 is that the super60 is oil cooled only. however, you honestly don't need to run the coolant lines on the saab/volvo turbos...just get some plug fittings for them and run it oil cooled only.
Just about all production cars that have oil and coolant lines are only to maximize the life in the turbocharger itself (150,000miles vs. 75,000miles) before rebuild or seizing.
me and my friends go get the saab/volvo turbos all the time, plug the coolant passages and run them oil cooled only without problems!
.48/.42 ratios are perfect for a D-series but I stay with my recommendation of the .60/.42 ratio T3 from the t-bird/merkur/cougar/svo mustang
Old Sep 17, 2003 | 11:43 AM
DigitalFusion's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stackz &raquo;</TD></TR><TR><TD CLASS="quote">yep, only difference between the saab/volvo T3's and the "super60" T3 is that the super60 is oil cooled only.</TD></TR></TABLE>
Thats not correct. The Super60 has a better compressor wheel than the 60trim wheel found on those turbos
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stackz &raquo;</TD></TR><TR><TD CLASS="quote">48/.42 ratios are perfect for a D-series but I stay with my recommendation of the .60/.42 ratio T3 from the t-bird/merkur/cougar/svo mustang</TD></TR></TABLE>
Its actually a 60/48 or a 60/63
boostedBLUfg2
Feb 14, 2011 11:32 AM
es_squared
May 8, 2008 07:21 AM
Tjabo
Sep 19, 2006 07:13 AM
hondaaccord94
Dec 2, 2005 07:22 AM
