CEL Code 3, MAP Sensor, car dies and weird low rpms throttle response.
Old Sep 8, 2003 | 11:13 PM
nEoMuGen's Avatar
Default CEL Code 3, MAP Sensor, car dies and weird low rpms throttle response.
The first time it came out was when I downshift from 5th to 4th gear, no misshift or anything, just went into low VTEC to pick up some speed on highway. It came out right after I went into fourth.
We read the code and reset ECU and it was gone. 1 week later, during an autox run, it came back on. Uptill this point, my car still drives fine, idles good but seems to rev up slower.
Today, I was in 2nd gear VTEC and it feels weird, after I came to a stop, the car dies off on me, I restart it and the rpm goes down again. I have to rev it for a minute to have it idle properly. Ever since that, throttle response in low rpm of any gear seems hesitating and my exhaust smells pretty bad as if I am running a test pipe.
Is my engine ok? Is it running rich? I plan to have the vacuum lines checked and have the sensor replaced, is there any other possibilities?
Modified by nEoMuGen at 1:51 PM 9/9/2003
Old Sep 9, 2003 | 09:17 AM
nEoMuGen's Avatar
Default Re: CEL Code 3, MAP Sensor, car dies and weird low rpms throttle response. (nEoMuGen)
hello?
Old Sep 9, 2003 | 09:40 AM
Fac3Man's Avatar
Do you know how to test the MAP sensor?
Old Sep 9, 2003 | 09:50 AM
nEoMuGen's Avatar
Default Re: CEL Code 3, MAP Sensor, car dies and weird low rpms throttle response. (Fac3Man)
nope
Old Sep 9, 2003 | 09:57 AM
Fac3Man's Avatar
Code 3 means you have high vacum.
Check the voltage between terminals 1 and 2 (left to right looking at sensor,key on position). Should be 5 volts, then check for continuity between terminal 3 and a body ground. I dont think you can check for amount of vacum without a scanner??
Just for reference since your gonna change it anyway, yeah just change the sensor. When you put it on make sure it seats correctly.
Old Sep 9, 2003 | 04:37 PM
K20DC2R's Avatar
it sounds like the map sensor. check the tps sensor also. gude luck.!!!!
Old Jun 4, 2004 | 10:05 AM
ShuaiGuy's Avatar
Default Re: CEL Code 3, MAP Sensor, car dies and weird low rpms throttle response. (VtecWhore)
Bump since I'm having the same problems now.
Old Jun 4, 2004 | 11:55 AM
mstewar's Avatar
Default Re: CEL Code 3, MAP Sensor, car dies and weird low rpms throttle response. (ShuaiGuy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShuaiGuy &raquo;</TD></TR><TR><TD CLASS="quote">Bump since I'm having the same problems now. </TD></TR></TABLE>
you should just PM neomugen, since he's still very active here..
Old Jun 4, 2004 | 12:29 PM
BlueR's Avatar
Default Re: CEL Code 3, MAP Sensor, car dies and weird low rpms throttle response. (mstewar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mstewar &raquo;</TD></TR><TR><TD CLASS="quote">
you should just PM neomugen, since he's still very active here..</TD></TR></TABLE>
no need to...his problem was fixed by cleaning out the back side of the throttlebody plate...no more CEL
Old Aug 25, 2006 | 07:52 PM
HickamHatch's Avatar
Default Re: CEL Code 3, MAP Sensor, car dies and weird low rpms throttle response. (BlueR)
bump cause mine does the same thing...
Old Aug 25, 2006 | 09:31 PM
mtber's Avatar
Default Re: CEL Code 3, MAP Sensor, car dies and weird low rpms throttle response. (93civic96ls)
If your car is throwing a code 3 constantly, simply check your map sensor via the helms manual and a multimeter.
If you have a vafc or some kind of hack installed into your harness, check the wiring
project91crxsi
16
Jun 2, 2011 08:30 AM
dsadas89das78934
11
Aug 27, 2004 06:47 AM
S2KP
Oct 7, 2003 10:15 PM
