Code 3 Map sensor ???? Help needed
Old Oct 6, 2003 | 08:28 PM
S2KP's Avatar
Default Code 3 Map sensor ???? Help needed
I recently got my hatchback boosted and my setup is b16a @ 7psi and v-afc hack. Its been throwing code three everytime I get on it around top of 3rd and in 4th gear. My problem is the car totally dogs out after I let off the throttle and try giving it gas again, feels like the throttle cable broke loose cause theres no response what so ever and the car is still running but won't rev up at all and vacuum drops.
Is the sensor reading too much voltage at only 7psi? Will hooking up a GM 3bar map fix this?
TIA
Old Oct 7, 2003 | 08:41 PM
S2KP's Avatar
TTT
Old Oct 7, 2003 | 10:15 PM
Del_Slowest's Avatar
Default Re: (Turbo_Siii)
Prolly you have the hack set too high -35, -34 etc..... you get my point. Some ppl have problems with it at -30 to -34%. This could explain why it's boggin on ya ( it has too much fuel ) and why it is throwing ya the code. hope this helps
eggie75
Apr 7, 2008 01:40 PM
JibOnALib
12
Sep 14, 2005 11:51 AM
ILLICON3000
Aug 4, 2004 03:25 PM
DOHCarp
Aug 23, 2003 11:58 AM
