Short Shifter
hey guys, i've noticed that some of the peeps up in here got the hcp linkage that comes with the motor mounts. my question is, wut year..model..make short shifter are you guys using? i currently have the short shifter for the crx, but it sux like shiet. do you use the 92 teg ones? aite thanx....for ur time...later
I have a better idea. do you still have your stock shifter? just take it to a machine shop, and have them shorten the shaft, thin and re-thread it. It also looks better, becuase your shifter will be much lower to the floor, and you won't have any problems with your linkage hanging any lower.
<----------Hacksaw special!
Actually doesn't seem to have really shortened the throw. I just did it because my shift **** sat about 4" above the boot, and it looked like ***. N ow it looks abou normal heighth.
I think if you want to shorten the throw, you have to cut off the shifter below the pivot ball( I guess is what it is called ), and lengthen it around 3/8's to 1/2 inch on bottom. that shortens the throw on top by having more leverage.
