Removing power steering from a 93 Integra DA style. Need help
Old Sep 7, 2003 | 08:20 PM
jonyb's Avatar
Default Removing power steering from a 93 Integra DA style. Need help
I'm removing the PS from my teg and there are a bunch of lines there that I am unsure of. Two lines go into the tranny, and one to the fluid cooler on the front. There is a supply line from the reservoir to the cooler, and so on. I removed the pump from the block and the line that goes under the car to the part that ties everything together. That line was capped off. Can I just cap off the line from the reservoir to the removed pump and be done, or can I remove all of it? Let me know the best way to get around this. Thanks
Old Sep 7, 2003 | 09:02 PM
hndarcrb18c1's Avatar
Default Re: Removing power steering from a 93 Integra DA style. Need help (jonyb)
You can remove it all just plug the holes on the speed sensor... May I ask Why you are removing????
Old Sep 8, 2003 | 02:38 AM
jonyb's Avatar
Default Re: Removing power steering from a 93 Integra DA style. Need help (hndarcrb18c1)
ttt
Andrew14
Jun 30, 2010 12:08 PM
full Circling
Jun 13, 2010 07:36 PM
be18see1
Jun 22, 2009 05:19 AM
3.504
Mar 8, 2004 09:00 AM
1.8EG-T
Aug 8, 2002 11:28 PM
