I need help on a swap before I invest
Old Sep 7, 2003 | 06:05 PM
Wicker Man's Avatar
Default I need help on a swap before I invest
I have a 97 Civic coupe EX and I desperatly need more power than what the SOHC v-tec is doing for me .... What engine would everyone recommend, Year, and is it basically bolt in ? Also what ECU should I get because I have seen my friends messing around with knock sensor wireing and wireing for everything else. I just want it to be as plug and play as possible. Thanks for your help.
Old Sep 7, 2003 | 06:07 PM
BauleyCivic's Avatar
Risky Business
Default Re: I need help on a swap before I invest (Wicker Man)
DO A ******* SEARCH....AHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH HHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH HHHH IT NEVER ENDS
Old Sep 7, 2003 | 06:14 PM
smnowell's Avatar
Default Re: I need help on a swap before I invest (BauleyCivic)
Might I suggest a B20A3... the original B-series motor. You will turn heads with this motor. If you pop your hood, people from all around with be impressed with this very rare and very powerful B-Series motor. This swap is the coolest of cool, fastest of fast, nicest of nice.....do what Bauley said and search, motor swap questions have been asked a million times
Old Sep 7, 2003 | 06:18 PM
Wicker Man's Avatar
Yeah yeah yeah call me a noob or whatever you want but I am stupid as hell and it takes me hours to get all the exact information I need by picking through each post and getting alittle bit of info so I wanted to get the best ideas then research them. I don't know too much about the ugly stepchild motor b20's. Are they v-tec ? And how am I going to hook up an older wiring harness to the obd2 mine has ?
Old Sep 7, 2003 | 06:20 PM
smnowell's Avatar
Default Re: (Wicker Man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wicker Man &raquo;</TD></TR><TR><TD CLASS="quote">Yeah yeah yeah call me a noob or whatever you want but I am stupid as hell and it takes me hours to get all the exact information I need by picking through each post and getting alittle bit of info so I wanted to get the best ideas then research them. I don't know too much about the ugly stepchild motor b20's. Are they v-tec ? And how am I going to hook up an older wiring harness to the obd2 mine has ?</TD></TR></TABLE>
Please stop talking...just search already. You are making yourself look even stupider. If you knew how to search, you would know the B20A3 is out of an 88 Lude. Its a 12-Valve, SOHC, Carbuerated (sp?) OBD-0 motor. See, this is why i told you to search, you can find out so much in so little amount of effort. The information you want/need for your swap IS on this message board, just gotta find the right threads...
Old Sep 7, 2003 | 06:35 PM
deepnite's Avatar
Default Re: (b16a ferio)
if this is the way u research things..my suggestion would be to just go to a shop and pay them for the whole swap and install
Old Sep 7, 2003 | 10:23 PM
EM1specR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wicker Man &raquo;</TD></TR><TR><TD CLASS="quote">v-tec</TD></TR></TABLE> vtec
Old Sep 7, 2003 | 10:27 PM
FF-sean's Avatar
Default Re: (EJ8specR)
listen and follow
Old Sep 7, 2003 | 11:19 PM
civic-si-2000's Avatar
Default Re: (ReaL JDM Eg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReaL JDM Eg6 &raquo;</TD></TR><TR><TD CLASS="quote">listen and follow </TD></TR></TABLE>
btw thats a huge piece of **** in your avatar
civiccoupegsr
11
Aug 6, 2007 02:33 PM
SoHc84
Jun 28, 2005 05:06 PM
crazydude75927
Mar 14, 2003 09:32 PM
