My friend needs SWAP help!!! ASAP!!!!
Old Sep 7, 2003 | 05:10 PM
Savv's Avatar
Default My friend needs SWAP help!!! ASAP!!!!
here are the posts for another board.....
I just did a 98 ex motor and trans swap into a 96 dx and used the underhood wiring harness but there is no wiring for the second o2 sensor. I know it goes up thru the floor from the converter but does it connect to another harness then to the ecu ? I need to have this fixed before noon on saturday. The problem is the dx harness had the sensors and converter right under the manifold. I have the converter with o2 sensor from the 98 ex also, any help would be appreciated
Seems like this isnt my only wiring problems. i got it runnin with an ex harness and 00 si ecu but the tach and speedo wasnt working and who knows what else wasnt working. I tried the dx harness that was in the car originaly with the stock dx ecu and it wouldnt even crank. There is also a problem I have with the head and distrib the Y8 distrib wont bolt up to the z6 head except with one bolt. This sux if it was anyone's car besides mine I'd prob not have a problem at all with this swap.....lol
It's a 98 ex block and trans and a z6 head into a 96 civic dx. We tried the 98 ex under the hood harness and 99-00 si ecu the car ran but the speedo and tach wasnt working and who knows what else. The dx under hood harness and ecu wouldnt even crank it it. Damn this sux. Guess this is what happens when ya try to do a cheap as possible swap. Oh yeah the the y8 distrib dont bolt to the z6 head but with only one bolt
Old Sep 7, 2003 | 05:37 PM
smallttocs's Avatar
Default Re: My friend needs SWAP help!!! ASAP!!!! (Wild0ne21)
https://honda-tech.com/zeroforum?id=18 just a suggestion
Old Sep 7, 2003 | 05:56 PM
Savv's Avatar
Default Re: My friend needs SWAP help!!! ASAP!!!! (smallttocs)
thanks........sorry, i didn't know where to post it
Whig-it
Mar 31, 2007 05:05 AM
pheen0m
Jan 17, 2005 12:57 AM
Savv
Sep 7, 2003 07:09 PM
boostedcivicsir
16
May 9, 2003 09:58 PM
