compression of a d15b7
anything above 135psi and with less then 28psi spread between any of the cylinders is acceptable.
good numbers are 165-250psi with spread of less then 10psi.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Btothe3rdDegree »</TD></TR><TR><TD CLASS="quote">decent</TD></TR></TABLE>
as long as they are all consistent it is fine...i have a D15B7 with a D16Z6 head...compression theoretically is now 10.1:1 instead of 9.1:1 I got 212, 211,214,213 they can be 150 or 250 like eg6ajk said, just as long as it is consistent
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eibach95Civic »</TD></TR><TR><TD CLASS="quote">where can you get a compression test done?? i would like to get myne done</TD></TR></TABLE>
http://www.sears.com/sr/produc...89000
Get one of those from sears...take out ur spark plug wires..screw that gauge onto the spark plug...crank the motor over for about 10 seconds...the gauge will throw a number at you (in psi) then repeat and do for each of the other ones...
just do 5 cranks of that cylinder. Have someone watch the gauge.
If you do 7 cranks on one cylinder and 2 on the next....the readings will be way off.
165, b15b7, bad, compression, compresstion, cylinder, d15b7, good, honda, loss, psi, psicompression, ring, tech, test
