Friggin' OBDII (tuning)
Old Sep 6, 2003 | 05:47 AM
Nick7's Avatar
Default Friggin' OBDII (tuning)
Well, got myself a SMT5 for tuning... u can edit MAP and ignition signals.
Anyhow.. tried now to lean somewhat mixture at low throttle/low rpm's, to find out that it's impossible.
Why? Cause stoopid OBD2 ECU tried to keep it at stoic A/F ratio!
For instance... I keep throttle at ~10% and rpm's at ~3000rpm (not in gear), and try to reduce fuel - rpm's go down a little... but soon, they go up again! And o2 readings are again same as were before - thus meaning ECU added fuel to compensate for o2 readings, even though I reduced MAP signal for 10% (that was just to test)!!!
Friggin' OBD2.. grrr....
Anyhow.. it it possible to run engine with o2 sensor disconnected? Or should I make something to fool it as if it's present?
Old Sep 6, 2003 | 06:18 AM
hondaconcepts's Avatar
Default Re: Friggin' OBDII (Nick7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nick7 &raquo;</TD></TR><TR><TD CLASS="quote">Anyhow.. it it possible to run engine with o2 sensor disconnected? Or should I make something to fool it as if it's present?</TD></TR></TABLE>
Your CEL will come on.. you can get a fake O2 sensor that give a fulty reading but depending on what the reading is the ECU will try to adjust accoredingly..
Your having about the same trouble as me. I have a 1999 Civic as soon as i installed a new CAI and 2.25" exhaust the ECU wants to idle the car at 200 - 300rpm.. as soon as you try to adjust it the ECU sets it back low until finally it throws CEL code 14 idle air valve error.
Old Sep 6, 2003 | 08:40 AM
Nick7's Avatar
Default Re: Friggin' OBDII (hondaconcepts)
Have you tried to detach o2 sensor?
.. well, will try tomorrow and see what happens.
But, if it will throw CEL - isnt it possible to 'fake' fixed voltage that o2 should send before it warms up - and keep that fixed voltage all the time making ECU think o2 sensor is not wamr enuff, and thus bypassing its readings?
Just wondering.... because that o2 sensor really ***** up things
the soL that could
Feb 17, 2006 09:27 AM
CHEETAH
Honda S2000
Jun 2, 2004 07:31 AM
nhez
Sep 20, 2003 08:03 AM
Nick7
Sep 10, 2003 08:47 PM
gsrbruin
Jun 25, 2003 09:15 AM
