axle-back and cat-back
Old Sep 5, 2003 | 05:50 PM
TrickHonda98's Avatar
Default axle-back and cat-back
I don't know this, but hell! everyone doesnt know everything. we all still have stuff to learn in life.
What is the difference between an axle-back and a cat-back?
wich is better to get? thanks in advance> have one
Old Sep 5, 2003 | 06:10 PM
Default Re: axle-back and cat-back (TrickHonda77)
bump, anyone?
Old Sep 5, 2003 | 06:42 PM
ciRcuitJerk's Avatar
jus f0 dekarayshunZ
the catback will go farther up your *** then an axle back...the axle back is shorter ...catback from the cat alytic converter back....axleback is from the axle back
next time search...im tired of owning you
Old Sep 5, 2003 | 06:55 PM
seppuku's Avatar
the names say it all...if you lay down under your car he stock exhaust (usually) have three or four sections (I know mine does Y7 I have a cat right off my manifold damn Y7). the first section runs from the cat to about where the front axle is (exact position varies)...in a lot of setups the cat will be location right after the first section...
The second section (again, depends on setup) usually runs from the cat or previous section to about the rear axle (many times this is where one of the resonators are placed.
The third section is from the previous section to the muffler or includes the muffler (ie, axle back)...cat backs usually include the second and third section of the exhaust including the muffler.
To answer your other question(simply cat back is better)...when buying any setup...always decide on your application. You need to make sure that the output flow of you engine, manifold or headers & cat match the flow of your cat back system
Hope that helps
Old Sep 5, 2003 | 07:09 PM
Default Re: axle-back and cat-back (seppuku)
thanx guys. and i tried a search already.
RELprojects
May 6, 2004 11:18 AM
deeweezy
Dec 5, 2002 12:28 PM
playabill19
27
Apr 11, 2002 09:36 AM
RACERSIR
Jan 11, 2002 09:08 AM
haloseven
11
Dec 20, 2001 11:06 PM
