are newer cars with chipped keys harder to jack?
Old Sep 5, 2003 | 06:36 AM
Hella Flush Kevin's Avatar
Ignore me . . .
Default are newer cars with chipped keys harder to jack?
i know old civics 96 and under get jacked alot and 95 and under integras. have you guys heard of newer models of the 2000+ civic, integras being jacked? i think the 2000 integras have chipped keys.
Old Sep 5, 2003 | 07:06 AM
rjr162's Avatar
Default Re: are newer cars with chipped keys harder to jack? (myspacebarisbroken)
it's alot more work considering the ECU will shut down the fuel pump and a few other things if the Immob system doesn't get the right code from the key. You could change out the ECU though to something that doesn't have a code just for the sake of driving the car away.
Old Sep 5, 2003 | 07:23 AM
x00gsr's Avatar
Some one broke into my neightbors type r. Pushed his car down the drive way and tried to hot wire the sucker. THey ended up tearing his ignition switch out and messing up his steering column...Too bad a couple months later my dumb neighbor let someone test drive his car and they never came back with it.
Old Sep 5, 2003 | 05:57 PM
tegmech's Avatar
It is one of the best ideas from the factory's that i have seen for anti theft. To steal it you have to jump the wire from one end of the "reciever" to the other.....Bitch and a half, so it does work well but not impossible to steal.
Old Sep 5, 2003 | 07:43 PM
foofighter's Avatar
if they want to steal your shiet they'll steal it these things just slow them down a bit more
Old Sep 6, 2003 | 10:06 AM
Vtecfool's Avatar
Default Re: (foofighter)
yea, they could always tow it if all else fails.
Old Sep 6, 2003 | 12:54 PM
drevinder's Avatar
Default Re: (x00gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x00gsr &raquo;</TD></TR><TR><TD CLASS="quote">Some one broke into my neightbors type r. Pushed his car down the drive way and tried to hot wire the sucker. THey ended up tearing his ignition switch out and messing up his steering column...Too bad a couple months later my dumb neighbor let someone test drive his car and they never came back with it.</TD></TR></TABLE>
he didnt go along for the drive?
does anyone know if you can put that into older cars (chipped keys)?
Old Sep 7, 2003 | 06:02 PM
LANDYcolorLAB's Avatar
To put that system in an older car is alot of rigging and changing, be easier and cheaper to buy newer with it already. Nothing is Impossible just either harder or more expensive jacking equipment is needed.
Old Sep 8, 2003 | 09:45 AM
nOOber's Avatar
Default Re: (drevinder)
"does anyone know if you can put that into older cars (chipped keys)?
do a search on "boomerang 2" it's a passive starter kill that comes with a transponder on a key chain. when you start the car... The starter kill module needs to see the transponder chip from the key chain in oder to bypass the SK.
You mount a pick up coil some near the ign. switch, so the key chain thing is close enough to trip it...
Instead of using the starter wire in the car ( the wire that gets cut and "killed"), you could use one of the wires off your ecu...
vtackin
Apr 24, 2015 05:35 AM
mouab18c1
Engine Management and Tuning
35
Aug 31, 2010 05:31 AM
Fuzzy Rhubarb
14
Jan 22, 2010 12:59 PM
nrgetic
Audio / Security / Video
May 16, 2005 09:00 PM
acurciv
May 29, 2003 11:39 PM
