Trannny problem... what u think it is?
Old Sep 5, 2003 | 02:53 AM
silverCRXTC's Avatar
Default Trannny problem... what u think it is?
alright yesterday after class, my crx wouldnt go into gear at all while running. i turned of the car and it goes into gear fine, i could shift while running but i got it home, i adjusted the clutch and it fixed it and i drove it for like 10 miles, this morning just before work, it did the same thing, what u think it is? clutch?
thank for any help
Old Sep 5, 2003 | 04:27 AM
Default Re: Trannny problem... what u think it is? (silverCRXTC)
update. now i went to try it again and its works fine wtf?
any ideas? i have a centerforce cluth with about 25k on it u think its shot?
Old Sep 5, 2003 | 05:01 AM
also ive been hearing a wierd rattling noise from the front and cant figure it out i wonder if its all related?
Old Sep 5, 2003 | 05:10 AM
OptimusPrimeX's Avatar
Dont know if this will help at all, or even if its your tranny or clutch?.. but take a look here... I would assume that its your Transmission... but just to be on the safe side, do some research on it, and do what you feel, cause i cant drive your car
https://honda-tech.com/zerothread?id=494094
Old Sep 5, 2003 | 05:26 AM
Default Re: Trannny problem... what u think it is? (OptimusPrimeX)
yeah im sure its not the tranny, i might change the clutch or just pray this doesnt come back,
and other suggestions?
Old Sep 5, 2003 | 05:33 AM
senpai's Avatar
You said it makes a sound; does it go away when you push in the clutch pedal?
Old Sep 5, 2003 | 05:39 AM
USDM 4G VTEC's Avatar
i had the same thing happened to me
and the clutch pedal got hard to push.
turned out that the spring that pushes the trow out bearing got bent and wasnt moving the bearing evenly out... was sideways and was getting caught...
i say just open and check before u buy a clutch
stapldnutz
Jun 19, 2006 09:48 PM
D-Rob
Mar 7, 2005 12:16 PM
Outkasted24
Sep 22, 2004 06:30 PM
