Will the ITR Pistons fit into a 1.6 B16a DOHC Vtec?
Old Aug 18, 2001 | 03:04 PM
is3oo's Avatar
Default Will the ITR Pistons fit into a 1.6 B16a DOHC Vtec?
Old Aug 18, 2001 | 03:42 PM
00 Si's Avatar
New User
Default Re: Will the ITR Pistons fit into a 1.6 B16a DOHC Vtec? (B16aVtecEK)
Y yes they will my friend. No prob there, but I recomend the CTR ones. CTR pistons = more compression that = more HP
Old Aug 18, 2001 | 05:18 PM
spoonek4's Avatar
http://tiiite.b16a.com/Specs/B16%2B17rodmod_1.jpg
If u wanna use any of these 'R' pistons in/on your B16A or B17A engine, you HAVE to do the following or else the 'R' piston will NOT fit. You do not have to do this rod-mod to any of the B18C/C1/C5 rods.
Old Aug 18, 2001 | 07:21 PM
MyDadsATerrorist's Avatar
New User
get the jdm ctr ones..11.1 c/r and get .25 over
http://www.jdmhondaparts.com/honda.htm
Old Aug 19, 2001 | 08:01 AM
CRX_VTEC's Avatar
Default Re: Will the ITR Pistons fit into a 1.6 B16a DOHC Vtec? (spoonek4)
The mod is actually for the rods to fit the wrist pins. I did it with my ls/vtec. The CTR pistons will fit fine. Not sure what compression you'll get with the CTR, probably around 11:1 or so. But the ITR's will work fine too.
Old Aug 19, 2001 | 01:46 PM
is3oo's Avatar
Default Re: Will the ITR Pistons fit into a 1.6 B16a DOHC Vtec? (CRX_VTEC)
I am about to buy some ITR Pistons from a friend. Should i hold off on those and find some CTR Pistons? Are there any aftermarket ones that are better than the CTR? Sorry if these questions are kinda dumb but i am kinda new to all this. I just got my b16a swap and i wanna learn more about on how to make my car alot faster. I love VTEC
[Modified by B16aVtecEK, 2:54 PM 8/19/2001]
Old Aug 19, 2001 | 02:18 PM
Tomei's Avatar
New User
Here is what my friend using on his 1800cc EK9 conversion. The pic here is the piston that he is using...:
And u can take a look on this list about what they are offering at this moment: http://www.aj-racing.com/pricelist01.htm
Pls feel free to email Jackie at info@aj-racing.com if u need further info on them.
Old Aug 22, 2001 | 01:48 AM
is3oo's Avatar
Default Re: Will the ITR Pistons fit into a 1.6 B16a DOHC Vtec? (VTEC2DaLimit)
Thanks for the picture. Now what kind of pistons are those?
Old Aug 22, 2001 | 10:27 AM
93delsol's Avatar
New User
civic type r
Old Aug 22, 2001 | 03:36 PM
CRX_VTEC's Avatar
Default Re: Will the ITR Pistons fit into a 1.6 B16a DOHC Vtec? (93delsol)
They look like CTR but dont seem to have the coating around the piston.
Old Aug 23, 2001 | 04:55 PM
Mike M's Avatar
Founding Member
In your sig it says Drag 3 Kit coming soon, I wouldnt reccomend Higher compression if thats the case. I would reccomend
Turbo - Forged Pistons with lower compression (9.5:1), Maybe Endyn's
N/A - CTR's for 11:1
Old Aug 23, 2001 | 11:14 PM
is3oo's Avatar
Default Re: Will the ITR Pistons fit into a 1.6 B16a DOHC Vtec? (TypeRmsm)
Yeah i know. Actually i need to change that. I plan on going turbo later in the future. Thanks anyways...
ELSUICIDA
Nov 23, 2006 08:55 AM
rallytyper
Feb 13, 2006 01:13 PM
greasemonkeys
Jan 7, 2005 06:41 PM
B16ACRX
May 16, 2002 11:02 PM
jdmb16acivic
May 31, 2001 05:23 PM
