Timeing retarded or advanced question?
Old Aug 18, 2001 | 12:44 PM
W0oT's Avatar
Banned
Default Timeing retarded or advanced question?
hey all i just completed my d16z6 minime head swap, and it's running well! but i know my timeing is off. it doesn't hesitate or bog or stall at idle or when driving. but when i let off the gas and get back on the pedal i hear like a preignition clack noise. i was wondering if my timing is + a fiew degries or - a fiew degrees. or if it could even be something else
Old Aug 19, 2001 | 12:36 PM
EG8R's Avatar
Default Re: Timeing retarded or advanced question? (Nismo240sx1)
find a timing light and check
Old Aug 19, 2001 | 12:40 PM
W0oT's Avatar
Banned
Default Re: Timeing retarded or advanced question? (skelly)
That's what i was thinking but i was just wondering first
Old Aug 20, 2001 | 06:27 AM
max's Avatar
max
ok, i have a mini-me swap and i know that the timing light will not tell u the right ingormation. i adjusted my timing so that using the gun i can see the arrow right between the 2 marks on the crank, exactly where it's supposed to be. but the car was slow, didnt wanna move and stalled a few times. i just advanced my timing, turn the dist towards the firewall, as far as i could and the car got faster and idle is more where it's supposed to be. i have the dist bolted using only the top bolt and the hole in the dist is drilled a little to fit the bolt. the hole itself is a little longer as the result though and i think i'll need to drill to make it even longer to advance the timing even more.
Old Aug 20, 2001 | 09:00 AM
W0oT's Avatar
Banned
Default Re: Timeing retarded or advanced question? (max)
that's exactly how i have mine set up, and i too still have to drill or grind out the hole some more so i can advance it some more. when we finished the swap, we just threw the dist on and turned it as far advanced as we could before it got stuck on a spot i didn't grind down far enough. it runs great but i know the timeing is off. what should the stock idle be my fields sfc vtec controller says at full running temp is low it's about 700rpms. but when i first start before the ecu goes to closed loop it's around 1300rpms. i posted pics on my web page too
Old Aug 20, 2001 | 10:07 AM
max's Avatar
max
when u put the new t-belt on what marks did u go by? on my head there were 3 marks on the cam pulley: 2 at 180deg and one at an angle to those 2 on the left bottom. there is also an arrow on head that seems to have to line up w/ that 3rd mark. but if i line it up, then the 2 marks on the top are not parallel to the head. the first time i put the t-belt on i went my the 3rd mark and i kept dieing wheneve i let go of gas. but when i readjust the tbelt using just the 2 marks and having them as parallel to the head as possible, the problem went away.
Old Aug 20, 2001 | 03:15 PM
kahren's Avatar
timign blah blha, nismo, make sure u fill up with atleast 91 octane, but about your sr20det that i am mroe interested in, do u road race that car, do u have a 1/4 time, and how hard was it to do teh swap...
Old Aug 20, 2001 | 06:20 PM
W0oT's Avatar
Banned
Default Re: Timeing retarded or advanced question? (kahren)
my nissan huh?.. the install is simple, the only thing that gives you problems is the battery. there is a lot of support for this swap. and many parts are interchangable. but to the digits. my car 90 nissan 240sx se fastback. running a red top sr20det 205hp stock. w/ greddy front mount intercooler, ACT clutch, HKS Super sequential BOV, Blitz Dual solenoid Boost controller, apex n1 catback, greddy down pipe...... and so on....... i'm running 18psi of boost on the stock turbo, pushing about 300hp to the wheels w/ intec Reprogrammed ecu. 1/4mile time of 13.1 . that's completely street drivable. w/ full interior. i drive my honda more than my nissan
92ehatch
Jul 28, 2007 05:40 PM
Ran4it2
Jun 27, 2007 12:52 PM
handa
Apr 11, 2005 10:36 AM
cjohnson_2
Mar 6, 2004 12:29 PM
91sihatchback
Jun 29, 2003 05:50 PM
