ls/vtec need help with cylinder head
Old Sep 4, 2003 | 07:43 AM
dan89crxsi's Avatar
Default ls/vtec need help with cylinder head
I bought a B18A1 ls block complete I have taken it apart and taken all the measurments to make sure it is ok now I want to get a vtec head for it and I am wondering what heads I can use on my block it is from a 1990-93 integra and I want to know what heads will work with my block?
Old Sep 4, 2003 | 08:07 AM
T4eg's Avatar
Default Re: ls/vtec need help with cylinder head (dan89crxsi)
All b-series DOHC vtec heads
You will need the complete head with intake manifold and distrubutor
GSR oil pump and timing belt
full-race dowl pins (or 14mm drill bit)
And a oil feed line
Old Sep 4, 2003 | 03:49 PM
Rukusmasta2's Avatar
Default Re: ls/vtec need help with cylinder head (BlueHatch00)
PLEASE build up your motor pistons,rods, balance n bluprint..and the head as well...do research b4 u jump into it so u dont run into problems
Old Sep 4, 2003 | 05:14 PM
VTECorona's Avatar
Default Re: ls/vtec need help with cylinder head (Rukusmasta2)
There are plumbing kits available for ls\vtec setups. I think http://www.jdmhondaparts.com has them.
With all due respect man, if you didn't know that any b-series vtec head would work are you sure you can handle this project yourself?
Old Sep 4, 2003 | 05:34 PM
BluePrintmfg.com's Avatar
Banned
if you are gona run the bottom stock I would use the GSR head cus it would bring the compression up alittle higher than the B16 heads. the GSR head has a P72 code on the front of the head and the b16 has PR3 code on the front of the head, I have both heads in stock at the shop if you are looking for one, just make sure that you know what youu are getting bro, I prefer getting stock heads and then doing work to them yourself. Some heads out there have been milled very much and etc. Let me know if you need any help.
Old Sep 4, 2003 | 06:20 PM
mr.beeks's Avatar
Default Re: ls/vtec need help with cylinder head (11sec.ALL MOTOR)
some links
http://www.theoldone.com
http://www.c-speedracing.com
http://www.importbuilders.com
Old Sep 6, 2003 | 09:48 AM
dan89crxsi's Avatar
Default Re: ls/vtec need help with cylinder head (VTECorona)
yes I think I can handle this myself I am in school for this stuff right now about to finish up the engines class and this is going to be the first motor I am building.....I thought that any b series head would fit but I wasnt just going to shell out the money for one and hope it would fit
Old Sep 7, 2003 | 12:36 PM
dan89crxsi's Avatar
I cant find a head for cheap I need one so I can get this engine in my car
Ben Petrocelli
May 4, 2019 04:46 AM
pakn-heat
Dec 1, 2009 04:17 PM
aira
Dec 24, 2003 12:40 AM
stock94
Nov 7, 2003 06:35 PM
sicilian2k1
Sep 2, 2001 10:39 PM
