what goes in to making a good ls/vtec swap?
Old Sep 3, 2003 | 05:42 PM
APP95bomexLS's Avatar
Default what goes in to making a good ls/vtec swap?
what components of an SI engine do you need in order to produce an efficient? if you put a gsr head on an ls block wouldnt that be an ls/vtec or wouldnt that just be a gsr engine? thanks for the feedback
Old Sep 3, 2003 | 09:30 PM
T4eg's Avatar
Default Re: what goes in to making a good ls/vtec swap? (APP95bomexLS)
a DOHC vtec head on a LS block is a LS/Vtec. The LS has more stroke than the gsr. You will need gsr or type-r oil pump, timing belt, full-race dowl pins (or 14mm drill bit) The complete head from valve cover down and Intake manifold, with distributor. And a oil feed line.
Old Sep 3, 2003 | 09:31 PM
RedLinin247
Guest
Posts: n/a
Default Re: what goes in to making a good ls/vtec swap? (BlueHatch00)
in other words... sell your ls and get a fuckign gsr.
Old Sep 3, 2003 | 09:32 PM
B16OnTop's Avatar
there aint no such thang as LSVTEC you cant put no VEETACH head on some non VEETACH block
Old Sep 3, 2003 | 10:22 PM
hmongboyLS's Avatar
try searching... there's tons of threads that has covered this topic
Old Sep 4, 2003 | 02:26 PM
projectTeG's Avatar
hey...there is sumtin called a ls/vtec...and it is a b-series vtec head mouned to a NON-vtec b-series block.....its just that they are unreliable if not built correctly
Old Sep 4, 2003 | 03:50 PM
B16OnTop's Avatar
Default Re: (projectTeG)
were you talking to me? because i know what LSVTEC is i was just being sarcastic because that is prob the most often subject a thread is created about here on H-T
Old Sep 4, 2003 | 04:15 PM
skribblah's Avatar
Default Re: what goes in to making a good ls/vtec swap? (hmongboyLS)
check out the thread in my sig.. its got some good info on ls/vtecs and what helps/hurts.
Old Sep 4, 2003 | 05:14 PM
91tegrals's Avatar
you know every time lsvtec comes up skribblah pops up with th info just check out his link it will answer youre ?s...
Old Sep 4, 2003 | 05:51 PM
VTECorona's Avatar
Default Re: (91tegrals)
It's not just the parts used, it takes good knowledge to make a mix-and-match motor such as a LS\VTEC work properly and be reliable.
Old Sep 4, 2003 | 06:06 PM
mr.beeks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91tegrals &raquo;</TD></TR><TR><TD CLASS="quote">you know every time lsvtec comes up skribblah pops up with th info just check out his link it will answer youre ?s...</TD></TR></TABLE>
what about me with the links LOL
http://www.importbuilders.com
http://www.theoldone.com
http://www.c-speedracing.com
Old Sep 4, 2003 | 06:39 PM
drumnatural's Avatar
Default Re: (francisco flores)
It all comes down to the quality of work.
go here for a good indication of work involved
Old Sep 4, 2003 | 07:55 PM
LSTEG96's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueHatch00 &raquo;</TD></TR><TR><TD CLASS="quote">a DOHC vtec head on a LS block is a LS/Vtec. The LS has more stroke than the gsr. You will need gsr or type-r oil pump, timing belt, full-race dowl pins (or 14mm drill bit) The complete head from valve cover down and Intake manifold, with distributor. And a oil feed line.</TD></TR></TABLE>
is he right? do u need the intake mani.... i can see distributor, oil feed line, timing belt, and the complete head... but do u need oil pump and the intake manifold??
helpmeplease
Oct 29, 2004 11:31 PM
mxler8
Jul 27, 2004 07:57 PM
PHiZ
Jan 28, 2004 08:44 PM
1man
Jul 28, 2003 10:01 AM
integra81
Nov 22, 2001 04:11 PM
